Posted May 11, 200719 yr I rewired my sub from 1ohm to 4ohm & was wondering do I need to reset my gains or redo the wiring config. from my amp to my sub ?My set-up is in my sig. line if that helps. It sounds the same but maybe not as punchy as before & it has a little less volume in the substage. I can hear my front stage alot better now also. Also I messed up & stripped out one of my screw mounting holes in my enclosure. Is there an easy fix or should I just go ahead & get a nut & bolt for it? Thanks, Chris.
May 11, 200719 yr Author Thanks. I figured as much but I think i'm going to go back to 1. I think I liked it better. I like to play with stuff to much lol! Later.
