Posted June 2, 200719 yr New woofers from Sundown Audio... the first run, which is available now, is a test run to see how these woofers stand with customers. I really like them myself and am proud to offer them. These woofers are 100% made in the USA of as many USA sourced parts as possible in a top quality factory. Sundown Audio will be offering the same warranty on our speakers as our amps -- 2 years limited / 5 year discounted replacement and the same applies to these even if they do *not* stay on board as a permanent product.If these are well received more will be built and they will stay on board as a permanent addition. These will be one notch below the "E Series" woofers previously discussed. The first run has no logos at all... if I keep these on as a permanent addition they will have a logo from the next run on.PARAMETERS AND ENCLOSURE SPECS:SD-1 10" / SD-1 12"RMS: 200 watts / 200 wattsMax: 350 watts / 400 wattsZ: 8 ohms / 8 ohmsRe: 6.93 ohms / 7.03 ohmsFs: 25 Hz / 26 HzQms: 8.8 / 10.83Qes: 0.36 / 0.53Qts: 0.34 / 0.51VAS: 67 L / 100 LBL: 17.5 NA / 17.0 NAMSRP: $110 / $125Enclosure recommendation is:0.5 - 0.75 ft^3 sealed on the 10"0.75 - 1.0 ft^3 sealed on the 12"1.00 - 1.25 ft^3 @ 30 - 35 Hz Ported on the 10"1.75 - 2.25 ft^3 @ 30 - 35 Hz Ported on the 12"These are both 8 ohm coils designed to work as a pair with the SAX-100.2 amplifier. They are very efficient and will do exceptionally well with that amount of power.PICTURES:* 10" SD-1 Cone* 10" SD-1 Back Profile*10" SD-1 Side Profile* 12" SD-1 Cone* 12" SD-1 Back Profile* 12" SD-1 Side Profile
June 2, 200719 yr Author Good looking subs. They are made to be a no-nonsense woofer for a good price I have been playing with them for a while but kept them quiet as a suprise announcement! I really want to try a pair of the 12" models IB in a rear deck.The "E Series" is still coming... but I needed these sooner due to the extremely shallow depth. I was seeing a LARGE demand for a good shallow mount 10" woofer and decided to do a 12" version as well.
June 2, 200719 yr Admin Good looking subs. They are made to be a no-nonsense woofer for a good price I have been playing with them for a while but kept them quiet as a suprise announcement! I really want to try a pair of the 12" models IB in a rear deck.The "E Series" is still coming... but I needed these sooner due to the extremely shallow depth. I was seeing a LARGE demand for a good shallow mount 10" woofer and decided to do a 12" version as well.That is true, the QTS of the 12 looks to be good for IB or nice sealed. SSA needs to do a 10" sub challenge and 18" sub challenge too for that matter.
June 2, 200719 yr These might wok out great for what I have planed for my Chrysler 300 install. Edited June 2, 200719 yr by rickyharrisjr
June 2, 200719 yr Author These might wok out great for what I have planed for my Chrysler 300 install.Let me know if you will be needing some
June 2, 200719 yr they look good Jacob! i think thats the bundle time for two SD-1 + 100.2 dont u think?i hope to get them shipped over here for testing aswell price looking good aswell!
June 3, 200719 yr Author Rony has his first shipment of amps now, I am hoping that things do well in Israel for him I will have more woofers following soon... I am still working on the "E Series" mentioned before as one step up from these. I have other ideas in the pipeline as well, should be very interesting!
