Posted June 4, 200718 yr what is the avereage gain when i pull out all the rear plastic????? i need to beat a guy in a local comp. i did a 151.4 and he did a 152.9 If i remeber right it was 2 db! Any help before next satureday would be great
June 4, 200718 yr what is the avereage gain when i pull out all the rear plastic????? i need to beat a guy in a local comp. i did a 151.4 and he did a 152.9 If i remeber right it was 2 db! Any help before next satureday would be greatI am assuming you have access to a TL?
June 4, 200718 yr what is the avereage gain when i pull out all the rear plastic????? i need to beat a guy in a local comp. i did a 151.4 and he did a 152.9 If i remeber right it was 2 db! Any help before next satureday would be greati accually lost when i pulled the interior and tested,are you competeing db drag? if so and your in a street class you c ant pull you interior
June 4, 200718 yr Author well that was a bust started out 1 db down from yesterday took out the plastic and gained my db back. still don't know where i lost a db in the first place.
June 4, 200718 yr Admin well that was a bust started out 1 db down from yesterday took out the plastic and gained my db back. still don't know where i lost a db in the first place.There are always ghosts in the machine.
June 5, 200718 yr well that was a bust started out 1 db down from yesterday took out the plastic and gained my db back. still don't know where i lost a db in the first place.Did the box shift at all? My brothers truck drops around 1 dB if the box is 3-4" to one side of the loudest spot!
June 5, 200718 yr Author no everything is in the same spot! they were stuck to the carpet from the resin being tacky
