Posted June 10, 200718 yr I have seen a few post that the BL can handle 1500w, but I am a little bit concerned about powering it with my SAZ1500D @ 1 ohm. I don't want to blow the sub, as I know the amp puts out a tad bit more @ 1 ohm than it's rated power. If anyone is already running this setup please let me know, so I won't make a mistake. Quintin.
June 10, 200718 yr what's the setup going to be? what kind of box? daily or burps? I have no experience with the BL but i feel save saying, more than likely you'll be fine. But i'd be weary of the mechanical limits of the sub.
June 10, 200718 yr Lots of guys run the 1500D on the BL Get to know your sub and it's limits and you will be perfectly fine with a properly adjusted gain.
June 10, 200718 yr Author Lots of guys run the 1500D on the BL Get to know your sub and it's limits and you will be perfectly fine with a properly adjusted gain.Well, I just wanted to make sure before I bought the sub that I could use it in that setup. I currently have my amp pushing a Q @ 2 ohms.
June 11, 200718 yr My bro's got a bxi2006 on his, so the 1500 should be fine. They're probably pretty close power wise, since the bxi is over rated a bit. I think you'll be happy. Edited June 11, 200718 yr by tejcurrent
June 11, 200718 yr Lots of guys run the 1500D on the BL Get to know your sub and it's limits and you will be perfectly fine with a properly adjusted gain.x2
