Posted June 13, 200719 yr OK I'll be ordering my Q 12 friday when I get paid. I am wondering if I should get the BP power option, and what it is excatly. I will have the alpine pdx-1.1000 on the sub and it will be in a sealed enclosure about 1.2 cubit feet. Thanks.
June 13, 200719 yr If you want to use a different amp in the future that'll put out more power than what you currently have, then it would be something to consider. It should help the power handling. If you won't be changing amps you'll probably be fine.
June 13, 200719 yr Author Does it help with cooling the sub or something? I thought I read a post that someone said that in? They said something along the lines of since it's going to be in a sealed box I would go with the bp power option it think. Also for 4 ohm I need the dual 2 vcs right?
June 13, 200719 yr i probably wouldn't either unless you know you're going to be upgrading amps. My Q is sealed and getting somewhere in the 1200-1400 range and it is fine.
