Posted June 18, 200719 yr I haven't built it yet I am just exploring options and found a design I kind of like. 8 cu. ft. tuned to 34 hz with 101.25 square inches of port. The port opening will be 4.5 " wide and 21.5" long. The box dimensions are 33x24x27.5 overall. It will be a crx style box , and will go inside of the cab of a 2000 chevy silverado. I plan on pointing the port towards the driver's side and have the sub behind the passengers seat. Do these specs seem alright to everyone? Would a different direction with the ports yield better results? Does that tuning seem alright or should I go lower/ higher? I want SPL but also enjoy the low notes that a highly tuned box sometimes lack. If anyone has construct a similar box, were you satisfied with the results? Thanks in advance for any help that you may be able to offer. Edited June 18, 200719 yr by lostcreeker
June 18, 200719 yr I haven't built it yet I am just exploring options and found a design I kind of like. 8 cu. ft. tuned to 34 hz with 101.25 square inches of port. The port opening will be 4.5 " wide and 21.5" long. The box dimensions are 33x24x27.5 overall. It will be a crx style box , and will go inside of the cab of a 2000 chevy silverado. I plan on pointing the port towards the driver's side and have the sub behind the passengers seat. Do these specs seem alright to everyone? Would a different direction with the ports yield better results? Does that tuning seem alright or should I go lower/ higher? I want SPL but also enjoy the low notes that a highly tuned box sometimes lack. If anyone has construct a similar box, were you satisfied with the results? Thanks in advance for any help that you may be able to offer.Sounds pretty good. I might be willing to give it a bit more port area, but unless someone else with more experience on the direction of port/subs has something to add, it sounds like it'll be good. I like my 34-35hz tuning. Still sounds great on the lows, but a lot of people seem pretty happy tuned around 32hz. It'll be retardedly loud either way you tune it, but I think your current plans should be fine- its your call.Good luck! Edited June 18, 200719 yr by tejcurrent
