I have a PDX-4.100 amp and I use the front two channels for components. I want to use the back two channels (200rms x2 bridged) for SD-1 subs. What would be the best combination of these subs for me to use to get the best bass? I can spend up to $250.
What box do you want to use?
Ported or Small Sealed, use the 10" model hands down -- two of them for a 4 ohm load.
Larger Sealed or Transmission Line, use the 12" model -- again, two for a 4 ohm load.
Either option will come out under your budget, contact a dealer for pricing (like the SSA store) and you will get a price quote that is less than MSRP.
I would do two 10" sd-1's ported to 30 hz.
Edited by audio-neon
thanks....it should be able to fit into my Toyota Camry right? (with SOME leftover trunk space?)
Edited by Invisible23
I'll probably use a ported box so I think i'll go with two 10"'s. Thanks for the help. Can't wait to hear them.
Any recommendations on a good ported box?
Yessir, just like the one Rich (stratusrt01) made for me:
2 ft^3 tuned to 30 - 35 Hz in a 2002 Civic LX trunk.
He can make one just like it for you for around $150 or so I believe.
I would start with the 1.0 @ 30hz (per sub) listed from Sundown and go from there. :)
That looks pretty sweet. How can I get in contact with Rich to build me one?
Where can I get the SD-1 for the cheapest price?
http://www.soundsolutionsaudio.com/shop/in...p;productId=146 If I buy 2 from there plus a $150 enclosure, then it would cost me about $370. It's a bit over my budget and I could probably afford it anyway but I was just wondering if I could buy the SD-1's cheaper?
email [email protected] for a quote. :)
