Posted July 3, 200917 yr Last weekend I made up a modified MJ-18M and we decided to do some power testing using a SounDigital SD-12k. This unit has a single 1 Ohm voice coil and a couple of other mods:The box we placed it in. Not sure what the size or tuning was as it belonged to Murilo. Perhaps he can comment on it:First test went fairly well with 1.5kw:Second test did better with more power:Third test was with 11.6kw of power:Fourth test didn't produce any more output but the FrankenMJ took quite a bit - almost 16kw(!):That's pretty decent power for a single SD-12k amp!
July 3, 200917 yr Ya that testing session was pretty crazy. I couldnt believe it took that power. Fun Times!
July 4, 200917 yr Author Yeah, despite the crappy weather it was fun. I want to get Murilo to BassRace it now... hehehe
July 6, 200917 yr Author So we did a BassRace with the same driver today. We found that 4kw was a bit too much for it. 3kw is more the happy place.This would be a good driver to use at 139.9
