Posted September 15, 200917 yr i need help choosing between these two designs for my 12" BL. my last box didnt turn out so well. so i was hoping you guys can maybe help me out a bit.amp:hifonics bxi 1606dgoal:splfirst design:H:14.25"L:30.5"W:18.25"port width: 3"total port length: 29.75square port area: 38.25box volume:2.9 cu ft (before double baffle)tuned to:34hzsecond design:H:14.5"L:30.5"W:14.25"port width:2.5"total port length:31"square port area:32.5"box volume:2.18 cu ft (before double baffle)tuned to 36hzany input is appreciated, thanks.
September 15, 200917 yr Author what was wrong with your first box?bl just didnt sound good, there was hardly any excursion and it wasnt loud at all. i think it was due to lack of port area.
September 16, 200917 yr Did it have a full 1000 watts going to it? What were the size and tuning frequency of that box?
September 16, 200917 yr here is the box that i am currently using. the tuning is actually 34 hz, even tho it says 32and the 3.5 cuft is supposed to be 2.5, just a few typos. lol Edited September 16, 200917 yr by Anton Miller
September 16, 200917 yr That box should have that sub moving plenty. Did turning the gain up not make a difference?
September 16, 200917 yr Author Did it have a full 1000 watts going to it? What were the size and tuning frequency of that box?it was somewhere around 2.5 cu ft tuned to 36hz. the thing about the box that i remember was that the backside of the L port was about 26-27 inches in length.i think that was the problem. in the end i wasn't pleased with the output, it moved very little air.
September 16, 200917 yr Author when my car is running my voltage is at a steady 14.4v, so it should have had the full 1600 watts going to the sub. how do you post pictures on here? i found a pic of my old box saved on my computer but i dont know how to post it on here.
September 16, 200917 yr when my car is running my voltage is at a steady 14.4v, so it should have had the full 1600 watts going to the sub. how do you post pictures on here? i found a pic of my old box saved on my computer but i dont know how to post it on here.Open an account at photobucket.com or post them to your gallery under your profile section on this forum.
September 17, 200917 yr Author specs of my old box.14.00" h14.50" D35.00" WTotal inside volume BEFORE sub & port displacement = 3.15 cuftPort dimensions = 3" X 12.5" x 36 (L PORT)Port volume = 0.95 cuftSub displacemnt = 0.150.95 + 0.15 = 1.1 cuft.2.0 + 1.1 cuft = 3.1 (within .05 is close enough)tuned to 35hzmy headunit has a high pass filter which is offmy amp setting when i had this box in.sub sonic-32 hzlow pass-80-90hzbass eq-0gain- set by dmm
September 17, 200917 yr Author posted some pics of the sub box, they are in my gallery under my username.
September 19, 200917 yr Author no one? i just need help from someone who's built boxes before to help me decide between the first two designs. my bl has been sitting at home for FOUR MONTHS without being played!!!!!!!
September 19, 200917 yr no one? i just need help from someone who's built boxes before to help me decide between the first two designs. my bl has been sitting at home for FOUR MONTHS without being played!!!!!!!Id say just build a box that matches Fi's site enclosure recc's..
