Posted October 21, 200915 yr Could you run a 4500D on 16v at .5 at it not hurt it? someone told me with the independence rise it wouldnt hurt it...jw if you guys knew he answer o bwt it will be goin on 2 12" BTL's..
October 21, 200915 yr Are you talking impedance rise? Are you running this daily or SPL? I would recommend running the amp for short durations at that impedance. Do you have the electrical to supply that amp?
October 21, 200915 yr Are you talking impedence rise? Are you running this daily or SPL? I would recommend running the amp for short durations at that impedence. Do you have the electrical to supply that amp?independence, lolAnyways, as stated, if you have a BEEFY electrical system it SHOULD be ok.However, I'll let jacob give you the final answer because I think he would know better than I would.
October 21, 200915 yr Of course 1/2 ohm is not covered by free replacement warranty... but I have tested at 0.5 and 16v with no problem.
October 23, 200915 yr Author Of course 1/2 ohm is not covered by free replacement warranty... but I have tested at 0.5 and 16v with no problem.ah gotcha well i am runnin it at 1 then thnaks for the info
October 23, 200915 yr Of course 1/2 ohm is not covered by free replacement warranty... but I have tested at 0.5 and 16v with no problem.ah gotcha well i am runnin it at 1 then thnaks for the infoGreat idea just in case something happens (which it wont it will still be covered). Make sure you buy Dual 1 ohm BTLs'.
October 24, 200915 yr Author Of course 1/2 ohm is not covered by free replacement warranty... but I have tested at 0.5 and 16v with no problem.ah gotcha well i am runnin it at 1 then thnaks for the infoGreat idea just in case something happens (which it wont it will still be covered). Make sure you buy Dual 1 ohm BTLs'.o i have them sitting in my room as we speak
October 24, 200915 yr Could you run a 4500D on 16v at .5 at it not hurt it? someone told me with the independence rise it wouldnt hurt it...jw if you guys knew he answer o bwt it will be goin on 2 12" BTL's..If you have to ask! then don't do it!
October 24, 200915 yr Author Could you run a 4500D on 16v at .5 at it not hurt it? someone told me with the independence rise it wouldnt hurt it...jw if you guys knew he answer o bwt it will be goin on 2 12" BTL's..If you have to ask! then don't do it!i didint know if the independence rise would effect it...and if u dont ask you'll never know...
October 24, 200915 yr Could you run a 4500D on 16v at .5 at it not hurt it? someone told me with the independence rise it wouldnt hurt it...jw if you guys knew he answer o bwt it will be goin on 2 12" BTL's..Are you sure you bought two Dual 1 ohm subwoofers because you stated in your first post that you wanna wire them down to .5 ohms, what voice coil configuration are you subwoofers?
October 26, 200915 yr Can you even wire two 1 ohm DVC subs down to .5 ohm?no! but check this out!http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12this is a sub wiring site! it is a very nice and easy to use! plus it by 12volt.com so you can't go wrong!
October 27, 200915 yr Author Could you run a 4500D on 16v at .5 at it not hurt it? someone told me with the independence rise it wouldnt hurt it...jw if you guys knew he answer o bwt it will be goin on 2 12" BTL's..Are you sure you bought two Dual 1 ohm subwoofers because you stated in your first post that you wanna wire them down to .5 ohms, what voice coil configuration are you subwoofers?I have dual 1's now...if i could run the amp at .5 i was gonna try to trade them off and buy or recone them to dual 2's..
October 27, 200915 yr Author hopefully you typed independence rise as a joke this time, its impedance rise.honestly i never knew the correct way to spell it...lol i jsut saw someone else spell it that way and figured it was right..sorry
