Posted October 23, 200916 yr how can i tell if i have 2 or 4 ohm coils if it dont say on the woffer Edited October 23, 200916 yr by danstow1
October 23, 200916 yr i think you can hook a meter up to it and find out that way. most of the woofers say what ohm it is either on the magnet or on the side of the basket
October 23, 200916 yr What kind of subwoofer is it? There's very few mainstream subs that don't give that information in either the model # or on the rear of the sub.... alot of the times the model # will have it included such as SWR-1222 (12" dual 2 ohm)..... otherwise subs like my Fi Q's have it written on the coil and it can be read through the vents above the magnet top plate.... Edited October 23, 200916 yr by Alton
October 23, 200916 yr Get a mulit meter and set it to ohms, touch the probes together and then hook up to the connections on the speaker.
October 23, 200916 yr Author Get a mulit meter and set it to ohms, touch the probes together and then hook up to the connections on the speaker. thats all you need to do and it should be disconnected form the amp right Edited October 23, 200916 yr by danstow1
October 23, 200916 yr Get a mulit meter and set it to ohms, touch the probes together and then hook up to the connections on the speaker.x2 or give us a model number so we can help you out a little bit.
October 23, 200916 yr how can i tell if i have 2 or 4 ohm coils if it dont say on the wofferAnswered.Reading > me
October 23, 200916 yr Get a mulit meter and set it to ohms, touch the probes together and then hook up to the connections on the speaker. thats all you need to do and it should be disconnected form the amp rightDo not have it connected to the amp
October 23, 200916 yr Author Get a mulit meter and set it to ohms, touch the probes together and then hook up to the connections on the speaker. thats all you need to do and it should be disconnected form the amp rightDo not have it connected to the ampSweet thanks guys
October 23, 200916 yr Ya the DMM are a must. If you get one, might as well get the clamp version. They come in handy.
