Posted October 28, 200915 yr My Current System2 AQ HDC315-A Subs1 XXV Maxximus7 Kenetik 1800 BattsBig 3 In 0 Gauge4 Runs of Power & Ground Wire (0 Gauge) (Each)5.5 Cb Foot Box After Displacements 38Hz w/ 2 6inch aeros2008 Jeep Grand Cherokee Laredo SUV270 "XP" Amp Alt From Dc PowerThis spring im doing 4 18's AQ Hdc3 New Coppers Off the XXV Maxximus. Tons of pics. Sorry some not in orderAlmost done with the current system. Just need to build an amp rack. Box Is a test box. Many to come. Trial and error. See what works best for the aq's all this power Also i would love some input on this. Thanks Edited October 28, 200915 yr by 08 Jeep Grand Cherokee
October 28, 200915 yr looking good.... what paint ( black ) and technique did you use for the base...... ?nice work and nice build thread...keep it comingchop
October 28, 200915 yr Author looking good.... what paint ( black ) and technique did you use for the base...... ?nice work and nice build thread...keep it comingchopThe paint? The paint color is black magic gloss (water base). White primer (water base)
October 28, 200915 yr Are you running wire under the car through the wheel well with no protection? If so, I wouldn't think that is a good idea. my two cents
October 28, 200915 yr Author Are you running wire under the car through the wheel well with no protection? If so, I wouldn't think that is a good idea. my two centskinda, theres rubber calking around the holes
October 28, 200915 yr Are you running wire under the car through the wheel well with no protection? If so, I wouldn't think that is a good idea. my two centskinda, theres rubber calking around the holesall the cable is exposed to the elements. kinda dangerous if consider, rain, puddles, road hazzards, etc.
October 28, 200915 yr Author Are you running wire under the car through the wheel well with no protection? If so, I wouldn't think that is a good idea. my two centskinda, theres rubber calking around the holesall the cable is exposed to the elements. kinda dangerous if consider, rain, puddles, road hazzards, etc.are u talking about the runs being under my truck? Alot of people do it. I have 8 runs from front to back. No way its going to fit under my carpet
October 28, 200915 yr Author Wow, that's a complete overhaul since September.yes sir! Btw im geting my own termlab by spring. Im going to fine tune this beast
October 29, 200915 yr Looking good, I would seriously consider some rubber around those wires in the floor for the sake of safety. Other than that looks like a lot of work. I think we have similar amps
October 29, 200915 yr I'd be more protective of those wires too. At a recent competition, someone's interior almost caught on fire because something was wrong with the wire outside the car. But good build and damn those amps are big.
October 29, 200915 yr Are you running wire under the car through the wheel well with no protection? If so, I wouldn't think that is a good idea. my two centskinda, theres rubber calking around the holesall the cable is exposed to the elements. kinda dangerous if consider, rain, puddles, road hazzards, etc.are u talking about the runs being under my truck? Alot of people do it. I have 8 runs from front to back. No way its going to fit under my carpetI said the same thing. to each is own.
October 29, 200915 yr Author I'd be more protective of those wires too. At a recent competition, someone's interior almost caught on fire because something was wrong with the wire outside the car. But good build and damn those amps are big.humm anyone know where i can get them rubber things? But some of the holes are realy big. so i need somthing to work. Should i put rubber pipe tubing around them at the holes?
