I may consider special orders for 10s.
I may have some special money for some special 10s by ETA!
  • Replies 85
  • Views 12.1k
  • jcarter1885
    jcarter1885
    Jacob definitely does not tell presale price before hand that will be something you will find out when he starts the pre-sale.
  • thebiggmann12
    thebiggmann12
    insane...10,000 watts...awesome!
I should have my prototype in hand next week... likely by Wednesday or so. Then I'll get some pictures of it put together as a 15 before I drop it in my Jeep!
The coil :
Left to Right : Monster D1 coil, NS v.2 D2 Coil, NS v.1 D1 Coil
It is a good bit heavier than the v.1 NS coil but about 15 grams of that is in the former as it is double thickness material.
Still 15g lighter than the Monster coil :)
The "standard" coil is very long... I will also be offering a 56mm version with 0.7 / 1.4 DCR... the long coils are 1.0 / 1.8 DCR.
Prototype motor is *supposed* to be here tomorrow too... so I should have more pics of it as well @ that time.
The coil :
Aww why did you have to post that, I havent even installed my Z15 v1 and you have me jealous already. :droolcup:
I WANT THESE SUBS!!!!
i gotta havem i gonna runnem lemme gettem...
Comparison : NS v.2 / Z v.2 / NS v.1
It's here ! I'll build it up once I'm done w/ shipping for the day to make sure it meets all my design specs.
And I jizzed in my pants... :lickscreen:
That motor is sexy. I am definitely inverting mine as soon as they come. Can't wait to see some test results with the new coil.
love NS v.1 :(
why not change the design of the basket?
magnets that have specifically compared to v1? diameter greater than or equal? thickness?
I love the design of the engine of the SA series, it would be nice to create this measure of the nightshade, like photos of the prototype of the "monster"
Edited by kkk4
The v.2 Nightshade has more excursion, more power handling, higher motor strength, etc compared to the v.1 model -- it is improved in every way :)
The flat back and top plate like the SA series and Monster series would make the NS v.2 too heavy! The top and back plates are both 40mm thick steel... this much weight would risk breaking the basket.
exactly
For this reason, talk of changing the design of the basket maybe
the diameter of the magnets is the same? the photo look the same, but with smaller thickness
exactly
Correct -- the magnets are shorter. With other changes to the design the motor strength is still higher.
It is not so simple as to change the basket design... tooling for baskets is extremely expensive !
have already made some tests on the resistance of the coil?
greatly improved cooling and power handling?
I remember a picture of a coil of the monster, and it was like that posed above (monster D1), but as long as that of the nightshade v2 ...
too big and heavy? :D
The 8-layer round wire for the monster is what you mean - it was only 56mm tall, though - the NS v.2 coil is 71mm tall.
Yes, that is the 8-layer round version of the Monster coil -- 56mm length.
I loved that :D
I've been looking for 30-45 minutes for my power clamp... no luck... so I cannot give power to SPL comparisons at this time.
Simply comparing HU volume levels... with my HU sub control at -3 this is the results:
MONSTER : 151.6 dB
NS v.2 : 154.0 dB
The NS may be seeing way more power due to reduced inductance... I have no way to know until I find my clamp. The Monster kept getting louder until the HU hit +6 as well where it did 155.1 dB.
I will do more testing later... had an issue with the samples coil formers / coil leads being too short so I had to rig it up to work... one connection broke in my testing. I am ordering new coil samples with taller formers / taller coil leads for production and further testing. I will try to rig it up a better way to get more testing until then, though!
wow!! nice number!!!
what were the ns v1 numbers? 1xx.5...my memory is failing me in my old age lol.
Edited by CrazyKenKid
I'm not done turning it up yet :)
Best ever was 154.3 with the NS v.1
awesome
nice!! and wasn't that on like ~7k ish.
i am looking for the thread but i am coming up dry. i think i remember that number.
