June 18, 201115 yr what does this thing meter outright? I saw the 156ish number pop.. I sat in it down in Daytona.. Seems louder than a 156..
July 13, 201115 yr keep breaking stuff trying to make this new windshield last a little while, but 56.xx at 40hz is about where its at, at the moment. does a 154.4 at 27hz 154.0 at 25hz 152.1 at 21hz
July 13, 201115 yr keep breaking stuff trying to make this new windshield last a little while, but 56.xx at 40hz is about where its at, at the moment. does a 154.4 at 27hz 154.0 at 25hz 152.1 at 21hzThats retarded that low.Good luck with that windshield, I dont see it happening. lolLooks like four 18's in a Geo gets loud 15's
August 10, 201115 yr Any plans for a stripper pole?if you look closely at the beginning of the vid you can see whats left of the old pole. It does stop flex, but the glass still breaks. But the metal on the edges of the welds is so thin it keeps ripping the base of the pole from the vehicles floor.
August 10, 201115 yr Any plans for a stripper pole?if you look closely at the beginning of the vid you can see whats left of the old pole. It does stop flex, but the glass still breaks. But the metal on the edges of the welds is so thin it keeps ripping the base of the pole from the vehicles floor.So that's what that little stub was I saw It's like you need some flat bar to run around the edges of the windshield, and rubber between flat bar and glass, then screwed down every 6" or so. Perhaps this would lessen the flex but also take away some "play area" for the windshield to move and actually crack easier?Or do some alan dante shit lol. (but then bumped into an extreme class?)I'm glad I'm not blowing out windshields
August 16, 201115 yr How many layers of tape is on that windsheild now?that was a new windshield. 3rd one so far.
August 19, 201115 yr How many layers of tape is on that windsheild now?that was a new windshield. 3rd one so far.Ouch!!Could a lexan windsheild be made for it?? Might be expensive, but being your on your 3rd one it's getting up there already. Would that be allowed in your comps?
