you can get huge gains depending on the box you build.... try sub up, port back...... try a bigger port area. try it alll
  • Replies 59
  • Views 6k
  • 1) Stop yelling or die. 2) A larger enclosure increases efficiency, making more pressure with less power input. You also take the risk of mechanical failure.
  • Generally with less air volume it will take more power input to achieve the same volume.
  • altoncustomtech
    altoncustomtech
    FIRST of all the amp itself has NOTHING directly to do with the number of DB's you can get. The amount of SPL you achieve has more to do with the driver, enclosure and their installation in relations
i was thinking of that making the port of the box bigger, now my box has a 3" port hole, making the port hole bigger will help me out?
well this is my box chek it out the port do think if i make the hole bigger will help me out gain som db's?
i got some pvc 6'' aero ports i can get for u .................... but with more batts i think u can get better score ............
someone told me to make a 1.3 or 1.7cu/ft box , use 6" aero port and tuned to 62 or 63hz, and that wil gain me up abput 3+dbs, but i think 1.3 or 1.7 is to small and 62 or 63hz is to high but i don't know, right now my box is 3.5cu/ft tuned 50hz slotport and i hit 146.5db, i don't know what to do
for starters what is your cars RESONANT frequency? and are you a ONE NOTE wonder?
personal opinion ditch the slot port box and pick up a 6'' aero.. about 35$ .. is much easier to play with tuning and port placement..
6" port is too small for a single 15. Go for 2 or even 3, IMO. Agreed that it's easier to test and tune with an external aero.
Too bad you are so far away. I'd send you a pair of 8 inch flares :(
Personally, for the xxx I'd build bigger boxes. 4+ cubes in your case.
My personal best with an xxx 18 was 147.9dB, 6cf and 12 inch aero. Couldn't fit a bigger box and have it work right in the car.
well i got new result i make a doble baffler and the port bigger, it was 3" before and now is 4" i gain 0.7db more, my new # is 147.2db's .
