Posted March 18, 201016 yr I am running a Pioneer DEH P7200hd and two Diamond Audio D1 6.5 components in my 2002 GMC Sierra. I want to run two 10"subs in a fitted down firing box under the rear seat(extended cab). I'm planning on using a Sundown SAZ1000D at 2ohms. The box I would like to use is only .77cu ft., which subs do you think would perform better in that limited airspace;2 Incriminater Audio 10" 187series or2 SSA 10"DCONor2 Resonant Engineering 10" SRxor2 Diamond Audio 10"D1?????Please help,thank you.p.s. any other suggestions would also be helpful, but I'd like to stay away from mainstream brands if possible Edited March 18, 201016 yr by tccoble
March 18, 201016 yr Author .77ft^3 Each chamber?yep, thats what the shop says. Unless someone knows of a bigger box that will fit under the back seat of a 2002 extended cab Sierra, that would be greatly appreciated. Edited March 18, 201016 yr by tccoble
March 18, 201016 yr The IA 187 would be the best fit for you! Single 4 ohm coils paralleled would yield a 2 ohm load.The DCON would work too but you would either have to run it at 4 ohm or 1 ohm mono!Know nothing about the other woofers. Maybe somebody else with knowledge on the others will chime in.
March 19, 201016 yr The IA 187 would be the best fit for you! Single 4 ohm coils paralleled would yield a 2 ohm load.The DCON would work too but you would either have to run it at 4 ohm or 1 ohm mono!Know nothing about the other woofers. Maybe somebody else with knowledge on the others will chime in.DCONs come in single 4 ohm coils.Going by manufactures recommendations the SRx would work.But if you were to throw a little poly fill in the enclosure you should be able to use any of those drivers.
March 19, 201016 yr why does your amp have to be run at 2 ohms when you didnt even pick your woofers yet???
March 19, 201016 yr My DCON is a dual 4 and they state dual 4 on the website!SSA Shop- SSA Dcon 10D4 Sub woofer300watt rmsSee the option to choose single 4 or dual 4.
March 19, 201016 yr Author why does your amp have to be run at 2 ohms when you didnt even pick your woofers yet???It doesn't really but I like the amp I've chosen and more powerful subs tend to be taller (too tall to fit in the box under the seat) and usually require more airspace than I have available.
March 19, 201016 yr why does your amp have to be run at 2 ohms when you didnt even pick your woofers yet???It doesn't really but I like the amp I've chosen and more powerful subs tend to be taller (too tall to fit in the box under the seat) and usually require more airspace than I have available.So just keep the gains on the amp turned down. You don't have to have everything maxed.
March 19, 201016 yr Author why does your amp have to be run at 2 ohms when you didnt even pick your woofers yet???It doesn't really but I like the amp I've chosen and more powerful subs tend to be taller (too tall to fit in the box under the seat) and usually require more airspace than I have available.So just keep the gains on the amp turned down. You don't have to have everything maxed.[/qu I just might do that, that's why I'm in here to get info and suggestions. I havn't built a system in 3 years and I dont even remember what the T/S parameters stand for, so I kinda lost touch. I also don't have time to re-learn everthing, I work 60hrs a week and have 4 kids to spend time with on my off time. So, thank you very much for the advice.
March 20, 201016 yr Admin Dcon or 187, it is a win win. Both have a great track record. I am biased, but either will be a quality choice, both in clarity and output in a small enclosure with minimal power.
March 20, 201016 yr Admin Hahaha! My Bad! Never looked at that!....We brought on the S4 option not too long ago. Technically it is a D8 internally bridged.
March 21, 201016 yr Author Massive Audio DC 10s?? I got a local dealer here who talking big about them. Anyone know anything?
March 22, 201016 yr Author Thanks everyone for the input, I'm going to go with 2 12" IA 187s on the SAZ1000D.
March 26, 201015 yr Thanks everyone for the input, I'm going to go with 2 12" IA 187s on the SAZ1000D.
