Posted March 23, 201015 yr lil build i did this weekend, 3 sa-12s on a saz [email protected], 6cf@30hz kerfed port sealed w glass. lots of sanding left and a outside glassing needed but sounds great
March 23, 201015 yr lol NICE job! the box looks awesome!!!with the march sale going on aer you going to buy another 1500? or is a single 1500 enough power for you?
March 23, 201015 yr Author this box is actuality for 3 z.2 12s on a 4500, and im sponsored and a rep so i dont think my price will change any, these bad boys are going into a wall in a 99 cavy 4 dr walled to the front seats, gana use 6 sa-12s on 2 1500s.... gana need about 1g in electrical before i get the zs and 4500
March 23, 201015 yr nice setup dude, do you measure the ohm load to the amp with a dmm? and if so what do i gotta put it on to do that. i always just thought that the number would be even like .5, 1, 2, 4 and so on.
March 23, 201015 yr Author nice setup dude, do you measure the ohm load to the amp with a dmm? and if so what do i gotta put it on to do that. i always just thought that the number would be even like .5, 1, 2, 4 and so on.havent clamped yet, i have a comp this weekend in union mo so will have tl numbers doing a 30 sec music avg and a 3 min avg, and 3 d4s wired in parallel ends up being .66667
March 23, 201015 yr Author i wasent sure having bat to alt to bus bar would be ok but it worked out well.... lil over kill haveing 2 runs of 0g flex and 1 run klmx 0g lol
March 26, 201015 yr looks great ... my suggeation is that you need a fuse within 18 inches from the front battery (your pulling alot of currect draw). Also good luck changing your air filter. I wouldn't trust your average oil change place to do it. Good luck with your build.
March 26, 201015 yr Author i do all my own work lol never would trust an oil place, i use royal purple lol. and its only a couple screws to get the the filter
March 27, 201015 yr Author will have tl numbers and some comp vids tomorrow, im running 2 classes, xrtm2 (30sec musical avg 12" outside passenger window) and kaos (3min musical avg at the front window) will also get a burp number just for giggles lol, wish me luck!
March 27, 201015 yr Author and on a side note, i dont really like fuse's they generate resistance and heat, i have never had a problem running w/o them and have had problems running them so thats y i dont use them, or solder my wires.... just add resistance
March 29, 201015 yr Author had a great day at the comp, place 2nd and 3rd, 30 sec musical avg 12" out side passenger window was 128.6, 3min musical avg at the dash was 141....... got a chance to clamp the 1500....... tehehe 1600w......@2ohm dropping to 12v... at 20hz tone..... steering wheel shakes up and down almost an inch at 20hz lol
March 29, 201015 yr Author also on class i was beat by 8 10" ia 187s on 2 kicker 2500s other class was beat by 4 9512s on a m4 so im happy rofl..... the 9512s only beat me by 1 db on 30 sec avg.... Edited March 29, 201015 yr by tyoung515
March 30, 201015 yr but really, thats some nice results. I need to find a TL in my area so I can see what my 8s do.
March 31, 201015 yr Author from what i have seen louisiana has a lot of ppl doing car audio shouldent be to hard bro, those 8"s are the beefyest i have seen for the money
