Posted March 28, 201015 yr is there any significant output differences between these amps. I would like the 1500 but its out my price range rite now. Besides the sae being unstrappable are there any advantages to using the saz. Still considering the sub at moment.
March 28, 201015 yr the saz is stable at higher voltages like 16v or 18v systems. u probably dont have that, so i would go with the 1200d. also, jacob has said himself that the sae1200d could be classified as a 1500 watt amp.
March 28, 201015 yr SAE are built to Jacob's spec in China, 12-14vSAZ are built in Korea to Jacob's spec, 12-18v
March 28, 201015 yr If you won't want to strap 2 in the future, go with the SAE1200v2. Looks way beefier than the SAZ1000D. Just my 2c.
March 28, 201015 yr The saz-1000d is NOT stable above 15v like the rest of the saz amps are. The sae-1200d makes more power. The saz-1000d has a lot smaller. Edited March 28, 201015 yr by Derrick824
March 28, 201015 yr i think the saz's can take a lower impedance. I believe they used to be warranted down to .5 ohms, but they changed that about a year ago to 1 ohm i believe. But they were doing fine with the low impedances
March 28, 201015 yr If your never gonna strap amps or go lower than 1 ohm then get the SAE-1200D for a little more head room. It is a toss up and you wont loose with either choice, so flip a coin if it is that hard to decide.
March 29, 201015 yr Uniform Amp Clamp Test - SSA Car Audio ForumandTesting all the SAZ amps - SSA Car Audio Forumhave you seen these yet??
March 29, 201015 yr Uniform Amp Clamp Test - SSA Car Audio ForumandTesting all the SAZ amps - SSA Car Audio Forumhave you seen these yet??Those tests are NOT measurements of power. As Jacob even cited they are just UNIFORM tests between them giving a rough idea of how they rank.1000w, 1200w, not an audible difference. IMO running beyond what is rated is dangerous unless you really know what you are doing. Either will be fine for your application.
March 30, 201015 yr SAZ-1000DRated power output:----RMS power, 2 ohm linkable/dual mono1800W x 1CH----RMS power, 1 ohm mono1000W x 1CH----RMS power, 2 ohm mono600W x 1CH----RMS power, 4 ohm mono300W x 1CHSignal to Noise Ratio >90dBLow pass frequency crossover 35Hz~300HzSubsonic filter 10Hz~60HzBass boost @ 45Hz 0~18dBPhase shift control 0~180 degreeFrequency response 10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm <0.1%Efficiency @ 4 ohm 86%Fuse rating 25A x 3Input Sensitivity 200mV to 6V (+/- 5%)Dimensions 252(W) x 58(H) x 294(L)mmSPECIFICATIONS:Digital Class-D Linkable Mono Block AmplifierDouble Sided Through Hole Epoxy PCB1 Ohm StabilityEfficiency : 86% @ 4 ohm, at 100Hz24dB/Oct Variable CrossoverMulti-Way Protection Circuitry (Thermal/Over Current/Speaker Short/Speaker DC Protection)RCA Line Input and Master Output24dB Octave Crossover SlopeVariable Subsonic FilterVariable Bass BoostVariable Low Pass FilterVariable Phase ShiftFour(4) Gauge Power Supply ConnectorsTested Voltage & THD : 14.4V & Less than 1% THDOperating Voltage : DC 10V~16VWired Remote ControllerMSRP $499 USDSAE-1200D V.2SPECIFICATIONS:1200 x 1 watts @ 1 ohm600 x 1 watts @ 2 ohms300 x 1 watts @ 4 ohms0.153v - 5.6v adjustable input sensitivityRCA Line-Out Jack15 Hz - 250 Hz Frequency Response> 90 dB S/N Ratio4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)50 Hz - 250 Hz adjustable 12dB Low-Pass Crossover15 Hz - 50 Hz adjustable 12dB Subsonic Filter0 or 180 degree adjustable phase switch0 - 12 dB adjustable bass boost with 60 Hz center frequencyWired Remote Control unit included5x 30 Amp Internal Fuses17" L x 10.6" W x 2.2" HMSRP $499 USD
