Posted April 19, 201015 yr Well saturday night I decide to go out and put some music.I noticed my 2000D blue light no longer turns on (the one on the amplifier). Sub works so amp still working.What could have happened? Why? and Should I worry about it?
April 20, 201015 yr Author Thanks JacobBtw, Im using my 2000D in 2ohms 1000watts RMS. Even tho Im not using the full 2000watts RMS, is it still normal that it gets hot? I was still able to leave my hand on top of it tho...
April 20, 201015 yr What is your voltage reading, what electrical upgrades have you done if any, do you have a good airflow around your amplifier?
April 20, 201015 yr Author I dont know my voltage reading. No electrical upgrades at all. Just using 4 gauge. Amplifier is under passenger sit.I dont remember it getting hot at all before. And Jacob told me 4 gauge was fine for 1k rms with no electrical updates.Im not worried right now. But will keep an eye to see if it gets any worse. So far everything is fine no cuts or dimm lights or anything.
April 20, 201015 yr Not a lot of air flow under a seat. That's probably the reason. It should be fine though.
April 21, 201015 yr Author Thanks for the input guys. Will definitely keep an eye on it and will notify of anything before anythings happens
