Posted June 2, 201015 yr so there's a show this weekend. getting tired of everybody talkin stuff about my sundown audio stuff cause they never heard of the name. i need to change my setup so i can win this show. my box is about 3.3 with 3 of the dual 4 sa12s. i running a 3000d @ 2.6 i have two options. either port my box i already have to stay behind the third row. or flip the seats up and build a 6 cube ported box just for the show. if i port my box i already have how high would i need to tune it. i need a mid 140's for this weekend. last show they held guy won it with a 139 or something. and i might add he had 4 15s in a box not tuned for the speakers. also would it be safe to wire it in parrallel so i can burp it this weekend?
June 2, 201015 yr port the box...use external aeros so you wound have to make that much of a change. or build a new box entirely
June 2, 201015 yr Author according to him that it wasnt bass race but he has to not know what he's taalkin bout i think
June 2, 201015 yr Author so there's a show this weekend. getting tired of everybody talkin stuff about my sundown audio stuff cause they never heard of the name. i need to change my setup so i can win this show. my box is about 3.3 with 3 of the dual 4 sa12s. i running a 3000d @ 2.6 i have two options. either port my box i already have to stay behind the third row. or flip the seats up and build a 6 cube ported box just for the show. if i port my box i already have how high would i need to tune it. i need a mid 140's for this weekend. last show they held guy won it with a 139 or something. and i might add he had 4 15s in a box not tuned for the speakers. also would it be safe to wire it in parrallel so i can burp it this weekend?how high do i need to tune it for my size box?
June 2, 201015 yr im not an expert in that man...but id say about 34 hz...use a big 8 inch aero...i dont know how long though...my guess would be about 10-12 inches
June 3, 201015 yr so there's a show this weekend. getting tired of everybody talkin stuff about my sundown audio stuff cause they never heard of the name. i need to change my setup so i can win this show. my box is about 3.3 with 3 of the dual 4 sa12s. i running a 3000d @ 2.6 i have two options. either port my box i already have to stay behind the third row. or flip the seats up and build a 6 cube ported box just for the show. if i port my box i already have how high would i need to tune it. i need a mid 140's for this weekend. last show they held guy won it with a 139 or something. and i might add he had 4 15s in a box not tuned for the speakers. also would it be safe to wire it in parrallel so i can burp it this weekend?how high do i need to tune it for my size box?What kinda car do you have?Get a frequency sweep, or a set of tracks with ~30-60hz test tones... Run through them and see which ones are the loudest, I guess you have a sealed box, so your curve will peak close to the cars best gain...basically go through the tracks and find out which is the loudest... if 50 is the loudest, tune the box to 45hz or so and test that, if you like what you see, run with it, if not try a lower or higher tuning, and see if you can get any more output out of it. You should be able to break a 140 with 3 12"s on a 3000D wired to .66 ohms.try to find out the ideal port firing and speaker position in your car, if its a trunk car, depending on how you install it, if facing the cabin, seal off the trunk to help prevent cancellation.Good luck! Edited June 3, 201015 yr by Rawr-dq
June 3, 201015 yr I went ahead and uploaded my test tone disk, upped it to mega upload....http://www.megaupload.com/?d=7WVBHS83 Edited June 3, 201015 yr by Rawr-dq
June 3, 201015 yr u need to let me know very soon OP about the status of your group buy because you will lose your place in it if you do not respond.
June 3, 201015 yr i hope to god you pull out mid 140s with 3k watts of possible power pushin 4 12's, since me and my friend are getting almost that much on 2k watts in the trunkbut to answer your question. i'd build a new box 6 net cubes ported so the air will flow to your passenger side, or where ever the meter is going to be around 43 hertz Edited June 3, 201015 yr by pdubb
June 4, 201015 yr well I would figure out how you lost and in what class? 139 from 4 15's in spl is crap now in bassrace thats a different story there is more to bassrace then you knowyou want to have some fun ditch the show in the springs and come on down to the summerjam show at cartoys. should be around 50 cars and lots to learn
June 4, 201015 yr Author well I would figure out how you lost and in what class? 139 from 4 15's in spl is crap now in bassrace thats a different story there is more to bassrace then you knowyou want to have some fun ditch the show in the springs and come on down to the summerjam show at cartoys. should be around 50 cars and lots to learni think i talked to you on car audio.com but i'm cutting a box at 6.4 cube box. im using the calculator on re audio but my brother claims the port part of the calculator is off. does anybody know of a different calculator?
June 4, 201015 yr well I would figure out how you lost and in what class? 139 from 4 15's in spl is crap now in bassrace thats a different story there is more to bassrace then you knowyou want to have some fun ditch the show in the springs and come on down to the summerjam show at cartoys. should be around 50 cars and lots to learni think i talked to you on car audio.com but i'm cutting a box at 6.4 cube box. im using the calculator on re audio but my brother claims the port part of the calculator is off. does anybody know of a different calculator?most of the calc's are a little differentPORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES
June 6, 201015 yr Author 150.7 with mic on passenger kick but i have to finish up grading my electrical
