jacob, i sent you an email about this, but you're stacked up on those.
can i get a set?
You can get them at Ace Hardware, they're 5mm screws. Plus, they're only like 10 cents each which would save you a few bucks since you'd have to pay for shipping.
there isnt one nearby, and i cant find anything simular around either
what about the post themselves (the thing the screws go into) Mine are stripped, can I get new ones? and solder them in myself if necessary?
Try a local auto shop such as Advance Auto, they're starting to stock more and more metric screws and bolts, they may have a good replacement available.
I would try getting a tap and tapping it out another size bigger with new set screws. I wouldn't want to disturb the solder joints on that circuit board. Otherwise you might be better off sending in to db-r for repair.
i had to re-tap mine on my 3k. 12/24 worked
