Posted June 27, 201016 yr jacob, i sent you an email about this, but you're stacked up on those.can i get a set?
June 28, 201016 yr You can get them at Ace Hardware, they're 5mm screws. Plus, they're only like 10 cents each which would save you a few bucks since you'd have to pay for shipping.
July 3, 201016 yr what about the post themselves (the thing the screws go into) Mine are stripped, can I get new ones? and solder them in myself if necessary?
July 3, 201016 yr http://www.homedepot.com/h_d1/N-5yc1vZ1xhc/R-202102298/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053 Edited July 3, 201016 yr by cheese20323
July 3, 201016 yr there isnt one nearby, and i cant find anything simular around eitherTry a local auto shop such as Advance Auto, they're starting to stock more and more metric screws and bolts, they may have a good replacement available.what about the post themselves (the thing the screws go into) Mine are stripped, can I get new ones? and solder them in myself if necessary?I would try getting a tap and tapping it out another size bigger with new set screws. I wouldn't want to disturb the solder joints on that circuit board. Otherwise you might be better off sending in to db-r for repair.
July 4, 201016 yr what about the post themselves (the thing the screws go into) Mine are stripped, can I get new ones? and solder them in myself if necessary?i had to re-tap mine on my 3k. 12/24 worked
