March 1, 201115 yr Author I just noticed I forgot to post up pics of my amp!! well here you guys go!and here are some gut picsand I just got this new head unit
March 1, 201115 yr Sorry I was a liittle slow on checkin out the vids. Guess it's movin' some air when you can't hang onto paper blowing out the window!
April 23, 201114 yr Author got some new vids, not very long though. i tried to keep it short due to the area i was at. just some random flex. And yes, i do know i need a lot of sound deadener.http://www.youtube.com/watch?v=cVRUaadmkEkhttp://www.youtube.com/watch?v=i0EVSLJkDRs
August 6, 201114 yr Author Well it's aBout time I updated this. I just finished wraping the box. Uploading pics now Edited August 6, 201114 yr by Bobobass
August 6, 201114 yr Author and heres some vidshttp://www.youtube.com/watch?v=AKBctJpZmzs&feature=channel_video_titlehttp://www.youtube.com/watch?v=2_3tlKZuklE&feature=channel_video_title Edited August 6, 201114 yr by Bobobass
October 8, 201114 yr Author going to be starting a new box. time to see just how loud a q can get Edited October 8, 201114 yr by Bobobass
October 9, 201114 yr Author what program is that? the 3d software is solid works and the box calc is tores box calculator Edited October 9, 201114 yr by Bobobass
October 9, 201114 yr Somethings not right about your dimensions. The calculator is off a bit and your drawing looks like the port is longer then what the calculator says.
October 10, 201114 yr Author Somethings not right about your dimensions. The calculator is off a bit and your drawing looks like the port is longer then what the calculator says.[/quote/]where is the calculator off? and the port is 24". the drawing is exactly what is in the calc. id just like to know what you see wrong before i start building
October 10, 201114 yr You should have 3 in the # of common port walls box and in your model it looks as if the wall after the bend is longer then the 2 inches its supposed to be.
October 10, 201114 yr Author You should have 3 in the # of common port walls box and in your model it looks as if the wall after the bend is longer then the 2 inches its supposed to be.thanks for the help. not the worlds best at designing boxes but im learning. heres the changes i made
October 11, 201114 yr Now you changed the length in the calculator but left it 24" in the model. And by the way, the 20" port would end in the corner causing incorrect tuning.
October 11, 201114 yr Author Now you changed the length in the calculator but left it 24" in the model. And by the way, the 20" port would end in the corner causing incorrect tuning.its not 24" in the model
October 11, 201114 yr OK so the ports 25.25" long, still doesn't explain why you put 20" in the calculator. That enclosure would be 6.58ft^3 @ 33.7hz using your displacements.
October 11, 201114 yr Author now i got the dimensions right. For all you reading this, make sure you mesure port lenght from the center of the port, not the inner port wall like i did. Edited October 11, 201114 yr by Bobobass
October 18, 201114 yr Author finally got to start building the new box. here are some pics of the pieces fitted together
