Posted July 24, 201016 yr Like the title says, my Nightshade v.2 12 D1 has showed up(fedex saturday delivery ftw). All I can say is wow, the wickedest sub I've ever seen! The comparison pics vs the SA-8 will show how big(61lbs to be exact) these subs really are. Hopefully the 1500d is up to the task, if not I guess Ill be upgrading my sundown arsenal somemore. Here are a few pics, I will post some initial install and testing impressions later.
July 24, 201016 yr dont drool to much that u get it all over the woofer bro! lolz, second 1500 would = ear sex lolz
July 24, 201016 yr Author negative on the wall socket, ill leave that one for someone else to do. I modded the 2.0ft^3 box I had for my 2 8's and put it in the truck, I can say its definetly louder than 2 of the 8s with the same settings on the amp. I will try and get a vid up later today and get the amp set properly.
July 24, 201016 yr nice~! and the v2 at that!! on 1500 it should sound nice! i know my 2-v1 on 5k sounds killer!!!!!! (15inch subs that is)
July 27, 201016 yr Author forgot the cutout, but its the same as any 12 with the 12 spoke basket NS v1 etc. mounting depth is 9.25 if i remeber right
August 3, 201016 yr Author sorry guys ive been slacking pretty bad on the vids. I gotta pull my seat out to adjust the amp properly, then I will get right on it.dvalue if you are ever in the lafayette area Im sure we could meet up, I go to BR every now and then I can send you a message if I know when I'll be headed that way again.
