Posted August 19, 201016 yr Runs on 240v AC -- supplying 260 amps continuous current set to 14.8vHooked up to some Stinger SPV-70s... need to get one more in there.Should do quite well... this replaces our prior setup of three Pyramid 40-amp units (only one recently as we blew up the other two). We went through those on a regular basis... this should be more reliable and much more power than we had before.
August 19, 201016 yr Author My Dad came in and installed the 240v panel for us (he was an electrician for 20+ years) -- each supply has it's own breaker.Brandon did all of the wiring on the board for the supplies themselves.Quite a bit of work in the whole deal but will make testing alot easier
August 19, 201016 yr Nothing like having a stout power supply set up for testing.That thing looks great!
August 20, 201016 yr shouldn't you need ~900 amps for testing strapped 4500D's? and that would make a great blow the video.
August 20, 201016 yr shouldn't you need ~900 amps for testing strapped 4500D's? and that would make a great blow the video.Typically Jacob does strapping in his vehicles
August 20, 201016 yr Author shouldn't you need ~900 amps for testing strapped 4500D's? and that would make a great blow the video.We don't test that kind of power on the bench - as was mentioned I'd do that in my vehicle.We also have a battery bank to back up short period high power testing.
August 20, 201016 yr Author still got/wanna get rid of the remaining 40amp pyramid unit?I'll be holding onto this one I've had it for almost 10 years... it's a bit of a Frankenstein inside from being repaired / modded of the years -- which is why all the others blew and it didn't *laughs*
August 20, 201016 yr ohh ok damn... i feel the sentimental value aspect.what brand/model are the ones your using now if i may ask? i'm tired of using a psu to power my saz1500 and once it gets bout 1/4 volume it shuts off. but im a broke ass and gotta find the best for less lol
August 20, 201016 yr Author 13.5V DC 25.8A 350W Regulated Switching Power Supply - eBay (item 390221420443 end time Aug-24-10 03:21:01 PDT)
August 20, 201016 yr still got/wanna get rid of the remaining 40amp pyramid unit?I'll be holding onto this one I've had it for almost 10 years... it's a bit of a Frankenstein inside from being repaired / modded of the years -- which is why all the others blew and it didn't *laughs*You have been doing stuff in car audio since you were a teenager? Thats crazy!
August 20, 201016 yr wow only 350w? guess thats why u got so many. my psu is 18amps 460w. i've got all the 12v(yellow) wired together and all the blacks together going to my amp should i add the +3v and 5v to the 12v? cause now that i look and think theres no way its gettin 460w right now
August 20, 201016 yr imma end up frying myself i better not even mess with it lol........but if u got any tips for me lemme know
August 20, 201016 yr Author still got/wanna get rid of the remaining 40amp pyramid unit?I'll be holding onto this one I've had it for almost 10 years... it's a bit of a Frankenstein inside from being repaired / modded of the years -- which is why all the others blew and it didn't *laughs*You have been doing stuff in car audio since you were a teenager? Thats crazy!Yep ! Brandon sold me my first system when I was 17
August 20, 201016 yr Author On music on a 3500D @ 1 ohm we didn't drop under 14.1 volts -- not bad at all !
August 21, 201016 yr wow only 350w? guess thats why u got so many. my psu is 18amps 460w. i've got all the 12v(yellow) wired together and all the blacks together going to my amp should i add the +3v and 5v to the 12v? cause now that i look and think theres no way its gettin 460w right nowno only use the 12V wires, also if your computer PSU has more then 1 12V rail that could be part of your problem. i have a PSU that will do 90 or 100 amps and 1k watts. the bigger problem for computer psu's is that there very sentivie and will shut down if it thinks it see a short, i can knock a power supply off line with some multi meters. get some sealed battery's and a trickle charger thats what i use. well not sealed for mine because my batts are out side.also cheep psu do not put out rated for long, or list there peek output power witch is for the power surge of start up. radio shack sells 20-25 amp ac / dc switching supplys that i like. you just need to find what works for you as a test bench power supply.hear are some old pics of my rig, it has more wiring now.and spare equipment that came from the good ol days.
August 22, 201016 yr Looks great! i wouldnt mind having getting a power supply or two for my own testing.
August 22, 201016 yr yeah i got several batts setting around 2 brand new ones. its just the charger lol we have 2 of em and neither one work its b.s..... probably gotta sell my sub this week to help keep our electricity and cable/internet on bums me out. but hey just gives me a reason to get new beats when i get my new car lol
