Posted August 25, 201016 yr which amp would be best for my 2 15 inch mtx 9500's. they are d4 coils so im gonna wire them at 1 ohm
August 25, 201016 yr Sundown Audio > AudioQueUltimately depends on your budget.. AQ is known for "Best bang for your buck"
August 25, 201016 yr Whatever fits your budget and has the power you need for your application, both will do the job.
August 25, 201016 yr Why do choose these amps ?Can your car handle more power ? So that you can run a more powerful amp !These MTX subs will play with 1500-2000 watts, but I know they can take more than that.save some more money, and find a more powerful amp if you can.I run sundown amps, and like them a lot. The Saz 1500 run my sub like a champ !!!
August 25, 201016 yr Whats the RMS rating for the MTX?If it's as above 1500w or so, the Crescendo 3000D would be a great amp. That's the best bang for the buck out there right now.If I was in the market for new amps I would be all over 2 of them for myself.
August 25, 201016 yr Whats the RMS rating for the MTX?If it's as above 1500w or so, the Crescendo 3000D would be a great amp. That's the best bang for the buck out there right now.If I was in the market for new amps I would be all over 2 of them for myself.They are rated at 1000w.
August 25, 201016 yr Whats the RMS rating for the MTX?If it's as above 1500w or so, the Crescendo 3000D would be a great amp. That's the best bang for the buck out there right now.If I was in the market for new amps I would be all over 2 of them for myself.They are rated at 1000w.Uh, well, never mind.
August 26, 201016 yr Author Whats the RMS rating for the MTX?If it's as above 1500w or so, the Crescendo 3000D would be a great amp. That's the best bang for the buck out there right now.If I was in the market for new amps I would be all over 2 of them for myself.the cresendo is over 500 im stayin under 400 for my amp i can get a sundown for 350 as well as the aq
August 26, 201016 yr each sub is 1000wrms , in this case id pick the AQlike some1 said above the cresendo wud be a great amp for these subs , save some $ & do it right the 1st time & make sure u have the electrical to back it up
August 26, 201016 yr I love how people say get the Sundown just cause it's Sundown even though the AQ will clearly fit his application better. LMAO.
October 1, 201015 yr Someone can explain if he heard a difference of sound quality between those amp??
May 23, 201115 yr Aq2200 gets my vote. You can also consider a Cadence ZRS-7500D http://www.woofersetc.com/p-8481-zrs-7500d-cadence-3600-watt-1-ch-competition-amplifier.aspx Edited May 23, 201115 yr by ricksi30
May 23, 201115 yr Im a Sundown nut-hugger...I am as well, but for this application the Audioque is a better fit.
May 23, 201115 yr AP3000D 300 SHIPPEDHe needs 1 ohm stability. If you meant Audiopipe. If you meant Planet Audio they can be had for about 200 shipped but I wouldn't compared to other options in his budget. Edited May 23, 201115 yr by ricksi30
May 23, 201115 yr Aq2200 gets my vote. You can also consider a Cadence ZRS-7500D http://www.woofersetc.com/p-8481-zrs-7500d-cadence-3600-watt-1-ch-competition-amplifier.aspxI think ricksi got over zealous and didn't look at the last post date of October 2010... lol
April 11, 201313 yr Doh, people are still voting on this. Yah, so what's it to yah lol .. I didn't pay attention to the date and someone bumped it by voting before me so meh.
