October 7, 201016 yr Can you run the rear two channels bridged for a sub? And the other two channels for front stage? Just making sure.
October 7, 201016 yr Are there any 2 channel amps that will be sold as well or are all 4 channel amps? ThanksFor this stuff, not that I know of. Just bridge the 4 channels. Wont work with my application since I will be using 4 ohm drivers and using 4 off them total, no problem though.
October 7, 201016 yr i sent the money.... came from Tracy Spears... any rough idea how long to get it shipped offThank you, and about a week. Cool..... Thanks.... and thanks for the good deal !
October 8, 201016 yr Author Admin Can you run the rear two channels bridged for a sub? And the other two channels for front stage? Just making sure.At 4 ohm mono I believe.
October 8, 201016 yr Author Admin Are there any 2 channel amps that will be sold as well or are all 4 channel amps? ThanksFor this stuff, not that I know of. Just bridge the 4 channels. Wont work with my application since I will be using 4 ohm drivers and using 4 off them total, no problem though.Get two.
October 8, 201016 yr Can you run the rear two channels bridged for a sub? And the other two channels for front stage? Just making sure.At 4 ohm mono I believe.Ok. I might just get one then
October 10, 201016 yr Author Admin Received my two about a week ago! Thanks again SSA!Awesome. Take pix when you get them installed.
October 14, 201016 yr I want mine! I'm jealous keep your eyes off , to be honest I do want another one myself.
October 15, 201016 yr I want mine, everyday I come home and check the porch hoping to get a surprise.
October 15, 201016 yr I want mine, everyday I come home and check the porch hoping to get a surprise. when did you order yours ? i am waiting for mine to........................
October 15, 201016 yr schweeeeet Jay-Cee !!!It's a nice looking amp; maybe it's just the plexi window ?!!!How do you like it ? what other amp can you compare it to ?:popcorn:
October 15, 201016 yr schweeeeet Jay-Cee !!!It's a nice looking amp; maybe it's just the plexi window ?!!!How do you like it ? what other amp can you compare it to ?:popcorn:Cant really compare it to any other amps honestly, I personally love the plexi top which will match another soon to have Zed Audio amp. I always wanted a Zed Audio amp so know I have one and its a Boss Amp, Im a fan of the old Boss Audio. I needed an amplifier to push my tweeters with some headroom as well and this provides me with my needs and at a great price. Currently I have it pushing my mids and it doesnt get hot, pushes my mids with ease and everyday I fine myself turning the gain down (seems to put out some real power). The only downfall is the crossover sections but hey thats what an active head unit is for or just buy some bass blockers for now like I did for my tweets. Not really a good reviewer or anything but hope that helps.
October 16, 201016 yr Admin mine showed up today...... sweet............... My roommates got three of them today!
October 16, 201016 yr Author Admin mine showed up today...... sweet............... My roommates got three of them today!
October 18, 201016 yr Ok. I have a question. Can I use 2 of these on a single D2 Xcon if i wire all 4 channels at 2 ohms for 720 watts rated power to each coil?Havoc REV-665•85wrms x 4 @ 4 ohms at 12 volts•180wrms x 4 @ 2 ohms at 12 volts =720 rms @2 ohms •190wrms x 2 bridged @ 4 ohms at 12 volts
October 18, 201016 yr Author Admin Umm, I am not sure I would recommend it, gain matching and such might not be worth it and could risk it. Not trying to turn down a sale, but rather say that you would be better off putting the money towards a single amplifier that is either a mono block or 2-channel.
