Im sefugis addopted son so what do you guys think about anouther fathe / son build by the master Gi 68 members have voted
  1. 1. who wants to see this build happen
Please sign in or register to vote in this poll.
:popcorn::drink40:
:woot:
  • Replies 261
  • Views 37.7k
  • The steering shaft should work now, hated to beat up these headers , its just how it is. By grasshoper at 2010-10-10 Had to trim back the slip sleeve on the shaft, and round down the inner shaft with
  • summit came through with the wrong radiator hose, but they overnighted the correct one with clamp and a water neck 90 degree swivel, pics to come after install and maybe a teaser video,
  • OK guys I cracked into grasshopper's pictures and this is what I found that he hasn't posted. I knew more had been done but the pictures havn't shown it. No disrespect, but the story has to be told...
Some specs on the motor
454 block .30 over , sonic checked, line honed
sealed power pistons,manly rod bolts, crank .20 rods, .30 mains
hastings bearings
stock oil pump, and pan , lokar dip stick
dart iron eagle 308 rectangle port heads / w/ cast aluminum tall series valve covers , w/ 4' k&n breather
1.7 roller rockers
rv cam 478/503 204/214
arp stainless hardware from top to bottom , a mix of 12 point and hex
gm performance parts serpentine set up w/ ac a little fab work to make fit
edelbrock performer air gap intake
holley street avenger carb 770 cfm electric choke
180 degree thermostat
k&n extreme air filter 4 "
msd hei distibutor
taylor 8mm wires
hooker super comp ceramic coated headers 2 inch primaries full length, {really want electric cut-outs} well see
mallory fuel pressure regulator
Transmission
th400 1800-2400 stall 10 inch converter
deep pan {extra capacity}
shift kit
lokar dip stick
I'm not a Chevy man but... :wackit3:
:wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3::wackit3:
You guys gotta stop that, the motors gunna be all sticky and I gotta help put this in the truck. :lol2:
:morepower1: thanks for the support!!
well the parts are all here at least most of the vital ones, what do you guys think , lets take a look well start with electrical to power that badazz interior!
By grasshoper at 2010-09-30
2 optima red tops and a little shot of welding cable
got a few 1/0 eyelets to get secure connections, and some battery terminal clamps
and a little more in the way of shiny
GONNA RUN THIS HOLLEY 770 STREET AVENGER WITH ELECTRIC CHOKE AND VACUUM SECONDARIES
dual feed line for carb , mallory fuel pressure regulator, and holley liquid filled fuel pressure gauge
taylor 8mm wires with a 45 degree boot
yeah I got lots of pics they really help to lay the foundation for the build
how about twin electric fans with controller
gotta have something to turn the rat over with, hum how about a racing starter!!!!!
Top of the line fasteners, all over this build
Gauges to keep tabs on everything, wohoo!!!
cant go wrong with lokar really nice quality, oil and trans dip sticks
energy suspention trans and motor mounts
