Posted September 23, 201015 yr I'm thinking about using one of these babies for my next setup but im a little confused about the power ratings...in the two reviews here:http://www.zedaudiocorp.com/Products/leviathan.htmlthe reviewers say it's rated 500w @ 4ohms 2 channels bridged and tested likewisehere its says 600w:http://www.soundsolutionsaudio.com/store/products/ZED-Audio-Leviathan.htmli would like to run my 2 sundown subs at 300/per but im not sure if i should go with 1 or 2 due to power ratings.edit: subs are the SD-1 v2's rated at 400w
September 23, 201015 yr Admin I spoke directly with Stephen, and I am considering running a Leviathan in Tri-mono. It is ratted for 3 x 300 @ 4, but he says it safely does 3 x 550.
September 23, 201015 yr Author I spoke directly with Stephen, and I am considering running a Leviathan in Tri-mono. It is ratted for 3 x 300 @ 4, but he says it safely does 3 x 550. wait 300 or 500? lol
September 23, 201015 yr Admin I spoke directly with Stephen, and I am considering running a Leviathan in Tri-mono. It is ratted for 3 x 300 @ 4, but he says it safely does 3 x 550. wait 300 or 500? lolJust like I said. ZED rates the amp at 3 x 300 @ 4, but it will do 500+ watts.
September 23, 201015 yr Author I spoke directly with Stephen, and I am considering running a Leviathan in Tri-mono. It is ratted for 3 x 300 @ 4, but he says it safely does 3 x 550. wait 300 or 500? lolJust like I said. ZED rates the amp at 3 x 300 @ 4, but it will do 500+ watts.now im even more confusedfrom the ssa store:Continuous Output Power 2 channels bridged into 4 ohm 600wx3Continuous Output Power 2 channels bridged into 8 ohm 300wx3
September 24, 201015 yr Author There is a typo some where, go with what I relayed to you from ZED. Ok thanks I believe those specs are on the pdf manual as well.
September 27, 201015 yr I spoke directly with Stephen, and I am considering running a Leviathan in Tri-mono. It is ratted for 3 x 300 @ 4, but he says it safely does 3 x 550. wait 300 or 500? lolJust like I said. ZED rates the amp at 3 x 300 @ 4, but it will do 500+ watts.now im even more confusedfrom the ssa store:Continuous Output Power 2 channels bridged into 4 ohm 600wx3Continuous Output Power 2 channels bridged into 8 ohm 300wx3So after reading this thread now I am scratching my head ... OK so I plan on wiring a DCON 12D4 so that the Leviathan sees a 8 ohm load (bridged). This means that the sub will get 300w continuous right? ... or will the Leviathan actually put out a different number?
September 27, 201015 yr Admin Yes, I think we should start the topic over. I think I made a typo along the way. The manual states 300 x 3 @ 8 ohm. So if you ran the Dcon @ 8 ohm off channels 5/6 bridged, it should be doing 300 watts. Chances are, with a ZED built amp, it has the ability to do more power.
September 28, 201015 yr Author Specification LEVIATHAN Continuous Output Power into 2 ohm per channel 250wx6Continuous Output Power into 4 ohm per channel 150wx6 Typical Output Power into 4 ohm per channel (1% THD) 175wx6 Continuous Output Power 2 channels bridged into 4 ohm 500wx3 Continuous Output Power 2 channels bridged into 8 ohm 300wx3 ^^^ copied straight from the manual.
