Posted November 15, 201014 yr Im getting a new system soon and i was trying to decided between the dc level 4 and the hdc3, i heard a couple saying that the Xl's are more comparable to AQ's, and i also heard many saying the dc's sound a lot better. My question is which will hit the lows better and sound better?
November 15, 201014 yr AQ subs are made for fart boxes. If that is your thing go for it, otherwise run like hell.
November 15, 201014 yr Admin i wanted to but the fully loaded btls are higher than bothSave up a few more dollars for American made original and quality designs.
November 15, 201014 yr Get a BL if the BTL is too expensive for you. Or buy used.You can find great deals on used equipments.Or save some more money !!!
November 15, 201014 yr Author and also going with the btl's ill have to change the amp that i want to get so im just going to keep it between the aq's and dc's
November 15, 201014 yr Admin because its a 3k wattsSo. There is no law saying you have to have rms power.
November 15, 201014 yr because its a 3k wattsSo. There is no law saying you have to have rms power.X2, just be smart and niece to the volume and gain knobs. You don't have to get the sub "fully loaded" talk with them about what you're planning to do and they can tell you what you should need to get, if any of the options. That's what makes them custom. If they were meant to be sold fully loaded to each and every person they wouldn't give you the options.
November 15, 201014 yr The DC Subs are just old FI designs which were sold by the owner of PSI to the owner of DC
November 15, 201014 yr and also going with the btl's ill have to change the amp that i want to get so im just going to keep it between the aq's and dc'sNot really, on the same amp the BTL is the louder driver even when not running anywhere near power.
November 16, 201014 yr Author I want a pair of 15's thats going to take abuse daily that plays deep with about 1500 rms
