Posted November 16, 201015 yr Mikes amp caught on fire.. so they decided to feed the little fire Oxygen, then it grew and grew then they put WATER on it..
November 16, 201015 yr you scared the shit out of me! I just saw you are having problems with the 100.4 popping and i thought that amp caught fire!
November 16, 201015 yr Good video, but sucks for himWhat brand is this amp? just to let people knowand is it me or are there loose power/ground wires around the amp? or did they disconnected during the bass test?
November 16, 201015 yr its an MA Audio amp.... You see it when they first open the trunk... Plus it has their mesh design heatsink...
November 17, 201015 yr When did they feed it oxygen?When they were blowing on it?Biology 101We inhale Oxygen and Exhale Carbon Dioxide.
November 18, 201015 yr Power supply failure. Until you disconnect the power, it will burn and burn and burn. Had something similar happen to me once. No bass all of the sudden, saw smoke coming out and I was lucky the amp had power plugs. Pulled out the plugs, no more fire. One of my amps blew 2 output caps once, big flames, left some marks on the back of the seat but continued to play....Now I always keep some big-arse wire cutters and at least one of the power wires accessible.
November 18, 201015 yr When did they feed it oxygen?When they were blowing on it?Biology 101We inhale Oxygen and Exhale Carbon Dioxide. C'mon banging I thought you would at least said when they opened the trunk up, some oxygen got in there.When did spitting on a fire ever put it out and why did they decide to pour water on an electrical fire, FTL
November 18, 201015 yr When did they feed it oxygen?When they were blowing on it?Biology 101We inhale Oxygen and Exhale Carbon Dioxide. You're joking right?If they blow from that kind of distance it will get more oxygen then Carbon dioxide. Nobody was smart enough to pop the hood and disconnect power wires? and then put water on it?
November 18, 201015 yr Author When did they feed it oxygen?When they were blowing on it?Biology 101We inhale Oxygen and Exhale Carbon Dioxide. You're joking right?If they blow from that kind of distance it will get more oxygen then Carbon dioxide. Nobody was smart enough to pop the hood and disconnect power wires? and then put water on it? Thank you Kirill
November 18, 201015 yr When did they feed it oxygen?When they were blowing on it?Biology 101We inhale Oxygen and Exhale Carbon Dioxide. You're joking right?If they blow from that kind of distance it will get more oxygen then Carbon dioxide. Nobody was smart enough to pop the hood and disconnect power wires? and then put water on it? He's gotcha there Tirefryr
November 19, 201015 yr Wow, I've never seen so many people not know what to do in case of fire.Hahahahahahahahahahahahaha
