Posted November 18, 201014 yr Hi I am new to the audio world and i am needing a little help.I have a 03 neon and I have a orion 25001 mono amp and i am wondering what i have to do to run the amp safely.the amp would be ran at 1ohm and I have a 4ch amp running mids and highs.
November 18, 201014 yr You did not say what you are using for power wire right now or if the 4 channel amp is already installed, but the Orion 25001 uses 1/0 inputs for power and ground so you will probly need a run of 1/0 from bat to amp with a 250amp fuse within 6-8" from the bat. and a 1/0 wire for your ground. That should get you started. Good Luck and maybe start a build log to show pics of what you are doing and through that thread you can get more info as you move along.
November 18, 201014 yr Might want to find out if the srt4 150 amp alt is a direct replacement for your stock alt as your going to need more than that stock alt can provide, make sure and do the big 3 in 1/0 and even get a second battery in the trunk to give some capacity to the system for a mono amp that large.
November 23, 201014 yr Author You need an electrical system for it, it takes power to make power.Yes, that is true thats why i posted the question. the amp is a monster and i want to use it but i dont want to burn it up by under powering it.
November 29, 201014 yr whats going on . I have to make these stupid post . So I saying whats up and Bass Da Nation Fool!
October 31, 201213 yr try at least doing a BIG 3 to your carNICE thanks for bringing up a 2 year old post for this lovley advice.
