February 6, 201114 yr So this will be compareablt to the. BTL?im pretty sure Fi makes this woofer, along with the others. As far as the motor design looks similar to a double stacked Q, large backplate. spiders and leads look exactly the same as a Fi woofer as well.hopefully pricing is right because a n2 18" is only 470.and im sure the creators will have the upper hand on this one. IM SURE OF IT. Edited February 6, 201114 yr by chris the man
February 6, 201114 yr Admin So this will be compareablt to the. BTL?im pretty sure Fi makes this woofer, along with the others. As far as the motor design looks similar to a double stacked Q, large backplate. spiders and leads look exactly the same as a Fi woofer as well.hopefully pricing is right because a n2 18" is only 470.and im sure the creators will have the upper hand on this one. IM SURE OF IT. Just so there is no confusion, it is not a Q, quite different driver.
February 11, 201114 yr I have a questionWill the ZCON come out in 12" too?Since my plans have changed, I think I will be getting 2 SSA subs paired on a 4500D. First thought was XCONS but then thought about the ZCON and it might be a better choice depending on release date, models and purpose.
February 11, 201114 yr Admin I have a questionWill the ZCON come out in 12" too?Since my plans have changed, I think I will be getting 2 SSA subs paired on a 4500D. First thought was XCONS but then thought about the ZCON and it might be a better choice depending on release date, models and purpose.Yes, 12"/15"/18"
February 11, 201114 yr I have a questionWill the ZCON come out in 12" too?Since my plans have changed, I think I will be getting 2 SSA subs paired on a 4500D. First thought was XCONS but then thought about the ZCON and it might be a better choice depending on release date, models and purpose.Yes, 12"/15"/18"Let see denimI want to know if I got this right. XCON is FULL SQ while the ZCON will move towards SPL (just a bit) in the SQ________SPL spectrum. Am I right?SQ_______________________________SPLXCON___________ZCON______________BTL Just want to know I have my thoughts right Edited February 11, 201114 yr by slim142
February 11, 201114 yr Admin The Xcon has LOADS of output, but is not an SPL driver. Your little chart is pretty close.
February 11, 201114 yr The Xcon has LOADS of output, but is not an SPL driver. Your little chart is pretty close. Problem is I want the ZCON but I like more the dustcap on the XCON Not a fan of the little caps LOL Edited February 11, 201114 yr by slim142
February 25, 201114 yr You are getting very sleepy.You will send me zcons and when you awake, you will remember nothing.
February 25, 201114 yr You are getting very sleepy.You will send me zcons and when you awake, you will remember nothing. Good Luck with that!!
February 25, 201114 yr You are getting very sleepy.You will send me zcons and when you awake, you will remember nothing.Hurry up and give this man his Zcons.
February 26, 201114 yr Seizure more like it.That is one of the side effects, yes.Concentrate my friend, very sleepy.
April 8, 201114 yr I want an 18 please.. I hope these come out soon. I have been waitin so long to see these. YOU ALL BETTER PUT UP VIDS!! I want to buy one but ill be saving for a while so i NEEEEED to see vids in the meantime once they release.
April 26, 201114 yr Has this ZCON Sub died off or still going ahead?I believe they are behind schedule due to waiting on USA Made Steel!
