So, most of the parts are in. There's some fabricating that still needs to be figured out, but what the heck. Let's get the show started. Here is a pic of the ride:
2004 Suburban Work Truck Edition. It's white and has a rubber mat instead of carpeting on the floor. The interior, vinyl. 5.3 V8 and it's 4WD.
The main source is a Alpine IVA-NAV-1 with a pair of Concept headrest monitors for the rear passengers. No pics yet :(
Here is the front stage:
Precision Power 355cs components in q-logic kicks, but wait there's more. o_o Can you guess what these are?
One more pic.
Edited by onebadmonte
  • Replies 436
  • Views 42.1k
  • it's for the bass silly
  • manrossdamn
    manrossdamn
    in for epic build!!
  • onebadmonte
    onebadmonte
    Here we go the final stage of the doors. Before you tackle a project like this it's good to have all your nuts and bolts ready to go. I recommend a stash of 8-32s, 10-32s, and some 1/4-20 bolts. For t
no idea what the box is for but it looks like fun
Those look like the Adaire Extremest 7 inch mid bass drivers ...
AA 7"?
Did you mean Adire?
those must be some Neodym midbass speakers ! AURA ...or something else !
mpyre
Bingo!
I'll be doing a semi-active 3-way front stage off a Crescendo 1000c4. Two 6.5s per door behind the factory grills. :)
they are fantastic drivers. i have 6 , two in the Camry, two in my office as computer towers. and two spares. :dancing:
Did you mean Adire?
yes sir thank you ...
mpyre
same XBL2 motors ???
Tuned in for this. I must have a listen when it's complete!!
Nice equipment there :drink40:
  • Admin
:drink40:
Yep.
I'll let you know. :)
:morepower1: will not be a problem with the WARHORSE! TUNED IN FO SHOW!!!!!!!!!!!!!!!!!!!!!!! :peepwall::popcorn::drink40:
Here are a few pics of how I got the components into the q-logic panels.
I didn't have a 4"+ hole saw, so I improvised. I used a smaller saw to cut out the center. I sketched out the profile of the hole I needed to cut, then I scored the plastic with a blade. I used to some pliers to break off the scored pieces of plastic leaving me with a semi-nice large diameter hole.
I decided to make a backing ring to secure the mid to the panel. Here is the ring I cut at work using a CNC plasma cutter. :)
I am using rivnut style inserts to mount the driver.
Here is the installed product.
More on the way.
Really like the backing rings and the inserts!! :drink40:
