How much does it hit by, try shaving down where the speaker mounts if its not by that much?
Hits by a lot, actual baffle hits so I can't just trim it.
I'm gonna redo both doors in a few weeks when I'm not burnt out.
  • Replies 366
  • Views 30.5k
  • Pulled off door panel, did another layer of resin and mat. Tomorrow lots of sanding and bondo!
  • CrazyKenKid
    CrazyKenKid
    hey no worries man! any time I can help out no problem! it is funny though how it was almost 3db differences from the TL vs the Makeitlouder meter. because when I was using it was always +/- 0.75db o
  • Not sure how to calibrate it And my dmm certainly isn't fancy, but I figured if it's reading a constant voltage then it's probably working Perhaps because we're at different altitudes and climates?
Everthing is looking great Stef. I am definately tuned in for the duration of this build! :popcorn:
  • 4 weeks later...
Didn't I read that you got your Tbelt changed out? Did you get your enclosure from Andrew yet?
I can say from doing my son's sub enclosures that it is time consuming. We spent a ton of time sanding. Yes, as mentioned about fleece does soak up a ton of resin. I'm planning some door pods for my next project and I have been taking notes on all the glassing I have been seeing so hopfully I have a few more "tricks of the trade" before I get started. So many builders make it look so easy.
Tuned for more updates...
You are going balls deep into this build. Looking good.
I'm getting it changed this week :D One less thing to deal with.
As for the enclosure, we had some problems fitting the ports in the original design, so were doing a new box. It should be awesome when it's done :drink40:
The more glassing I do, the less sanding I find myself having to do. Perhaps I'm slowly getting better at it. I'm also in the process of moving, so I have the majority of my tools at the new house, so going back and forth in limbo land :P
I bought a cool looking amp for my mids and highs, vibe litebox 2 channel. Nothing fancy, but should be a lot better then hu power. Also got a cheap pair of vibe 6.5s just so I can finish up the door pods.
Hopefully next week I'll have a pod done and some new pictures :D
I think you need a Rockford Fosgate 400x4. :)
We need moar pics!
I only have 2 in front, no need for four channel haha
Did I miss it or you haven't put that Vibe in the car yet?
I don't have anything to take pictures of yet!
At 5pm today ill have the vibe amp and comps. Then I can start working on the doors, then plenty of pictures!
hurry it up slacker!
We need moar pics!
Nonsense! Bridge it! Then when/if you get another set... you good. :) u know you want it. Lol
:woot: :woot:
Package came early. I got the vibe stuff in. Pics soon :D
Good Vibe-rations!!
:woot:
Time to run rcas, speaker wire, and amp!
Those mids have some nice eye appeal!! What are the measurements on that amp? Looks really small but the specs on it seem pretty strong.
4 ohms: 90 watts x 2 chan.
2 ohms: 125 watts x 2 chan.
Bridged, 4 ohms: 250 watts x 1 chan.
Dimensions: 5-1/4"D x 8-1/4"W x 2"H
Just finished installing it, current hertz coaxials sound cleaner and a lot louder, too bad their only 5 1/4s with next to zero midbass.
It won't be long and your mb problem will be solved :)
That's the plan :D
I was originally going to get those hi-vis from madisound, but saw the vibes, looked cool, figured its a comp set, gotta be better then my coaxials, impulse buy :P
Some more pictures, just boring stuff
Haven't cleaned up wiring or anything yet, just temp until I finish up the sub area and figure out where everything is going. I think I'll make a cover behind the battery, and mount the amp on the side. Gotta love how small it is :wub:
Very nice! Me likey :popcorn:
give a review of the vibe equipment when you get the chance. i've looked at their products so many times that i'm losing it haha. looks good for temporary
