Posted March 18, 201115 yr well i found a new toy that loves the high notes.in our testing it was able to do a 155 outlaw @ 71hrtz with 1 NS12 and a 40.1 on 12 volt.this new vehicle is stock from head to toe. no damp,no duct tape nothing yet.since i was using a freind of mine equipment.I need to start getting my own again so I want to go with a lighter sub like 2 x sa10's and a [email protected] to start out with since i cant afford what I need.will the sa 10's hold up to some 71 hrt burps until i can afford some bigger subs and more power?this new vehicle is crazy loud to start out we tested for about 2 hours before we got to a 154.7 with a box that was just sitting in the garage. LOL once i find the sweet box,damp and some trick's I think I can get this close to a 160 outlaw.I've built and modded 6 box's so far even did a bandpass but the sub didnt like the 4rth order and the spiders all came loose.cant wait to get started BUT money is real tight right now for me and mine!
March 18, 201115 yr The Z peaks higher than NS and SA, check those out. Look out for issues with the SA series pounding above 1000wrms.
March 18, 201115 yr Author The Z peaks higher than NS and SA, check those out. Look out for issues with the SA series pounding above 1000wrms.cash flow!Sure they can but you will be buying re-cones this is not a daily driver setup it will be built and used with budget in mind. so finding the what these subs like and what will help them last a couple of shows will be keyEnjoy music for once not burps because its easier and cheaper to burp a high score then it is to build something to play 35hrtz everyday at the same high scoreIf you wanna keep it loud, don't put deadener at all.well thats what they said about the crx's when they first got used but now everyone and there mother with a crx dampen's them.also the next best thing is there is only a couple of interior panels.so it will be easy to dampen it and test and remove with in minutes
March 18, 201115 yr If you wanna keep it loud, don't put deadener at all.well thats what they said about the crx's when they first got used but now everyone and there mother with a crx dampen's them.also the next best thing is there is only a couple of interior panels.so it will be easy to dampen it and test and remove with in minutesUm, no one deadens them. Where did you get this information from?
March 18, 201115 yr Author If you wanna keep it loud, don't put deadener at all.well thats what they said about the crx's when they first got used but now everyone and there mother with a crx dampen's them.also the next best thing is there is only a couple of interior panels.so it will be easy to dampen it and test and remove with in minutesUm, no one deadens them. Where did you get this information from?not sure where you have been but you go on termpro and usaci forum and they will tell you that they deaden!terry brock has his dbl layerthe guy from cali that beat brocks street a score a couple years agoa person that took second the same year brocks score got beatamerican bass team there is a ton of crx's that are matteddc anna's crx is mattedthe list goes onbut like i said it's very easy to test in this vehicle.there is no removing panels and putting them back at allthe top 5 in this list had crx's and they all had deaenerdB Drag Racing - Street A Place Country Competitor SPL FoMax 1st Team XS SPL - Tuan 156.1 2nd Team SPL Bank - Scott 155.6 3rd Ryan Ferguson 155.4 4th Team Neo - Eric 155.3 5th Terry Brocks 155.3 6th Advanced Mobile Toys 154.6 7th Team Gameover 154.3 8th Edited March 18, 201115 yr by stevew007
March 22, 201115 yr The SA can take some good burp power... we have done 2.2k on an SA-8 stock copper coil @ 68 hz -- and they use a smaller 2" coil vs 2.5" on the bigger SA
March 22, 201115 yr The SA can take some good burp power... we have done 2.2k on an SA-8 stock copper coil @ 68 hz -- and they use a smaller 2" coil vs 2.5" on the bigger SAThe SA-8's are little beasts, but that is just INSANE!!
March 22, 201115 yr The SA can take some good burp power... we have done 2.2k on an SA-8 stock copper coil @ 68 hz -- and they use a smaller 2" coil vs 2.5" on the bigger SAThe SA-8's are little beasts, but that is just INSANE!!No joke!!
March 26, 201115 yr If you wanna keep it loud, don't put deadener at all.well thats what they said about the crx's when they first got used but now everyone and there mother with a crx dampen's them.also the next best thing is there is only a couple of interior panels.so it will be easy to dampen it and test and remove with in minutesUm, no one deadens them. Where did you get this information from?Mine's deadened, and the loudest CRX's are deadened as mentioned. If I can do 152's with a single SA8, I'm gonna say deadening probably helped.The SA can take some good burp power... we have done 2.2k on an SA-8 stock copper coil @ 68 hz -- and they use a smaller 2" coil vs 2.5" on the bigger SAYup, and not only did I do it once, I've done it hundreds of times without failure. I'd do a pair of SA's before a pair of Z's in that application.The SA can take some good burp power... we have done 2.2k on an SA-8 stock copper coil @ 68 hz -- and they use a smaller 2" coil vs 2.5" on the bigger SAThe SA-8's are little beasts, but that is just INSANE!!152.2 in the kick, 148.9 sealed on the dash worth of insane
