Posted April 13, 201115 yr Ok guys I have been looking at the DCONS for quite a while now and my birthday is comming up and I am looking at getting 3 of them for my truck and the amp I am looking at getting an audio que 1200D to power them all Do you guys think that will be enough power for them all also I will be making a custom box it will be 8 inches deep 59 in across 25 inches tall for the 3 12s do you have any ideas on what to do with the inside of the box build different chambers for each sub or put holes in the different
April 13, 201115 yr Admin I answered both of your emails stating that amplifier would be enough power.
April 13, 201115 yr Do you guys think that will be enough powerDo you have any ideas on what to do with the inside of the box build different chambers for each sub or put holes in the differentYes that amp would be fine.No idea what your asking on that second question.
April 13, 201115 yr Are you wanting to go ported or sealed. Those measurements give about 5 cu' so your going to be a little limited on ported unless you find a little more space.
April 14, 201115 yr Author Are these subs going to hit hard in a single cab you guys think? I am looking to getting a really loud system
April 15, 201115 yr Even with 3 in a 5cuft area he should be good. But either ported or sealed, 2 or 3 you will be doing good with these, these subs are overlooked quite often, but are certainly little powerhouses.
April 16, 201114 yr Author i have blue neon in the cab of my truck and also HIDs lowering kit and much more
April 18, 201114 yr Author i am going back and forth between the 10 and the 12 what do you guys think?
