July 22, 201115 yr Author i ordered 4 12" Eminence delta mids...tested on my receiver in the house....LOUD...on no power....they're gonna see 400+w EACH in the hhr... few weeks ill order the 8 8's as well, those will see around 200-225w each.heres a sneak peak. 1x 12 and 2x 8's per front door, and 1x 12 and 2x 8's behind each front seat. 12 mids in total, and about 3400w rms total. 8 bullet tweeters as well (2 per door and 2 behind each seat) with about 125w rms each tweeter. should get loud this is the 12. its huge. and loud. ima be deaf, thats for sure!
July 22, 201115 yr Wowzaa those mids right behind your head will make quick work on making you def! Is suede hard to work with? I love the dash wrapping you did
July 22, 201115 yr i joked around about this several nights ago, but your doing it !!!! wow bro, awesome approach.....
July 23, 201115 yr Author Wowzaa those mids right behind your head will make quick work on making you def! Is suede hard to work with? I love the dash wrapping you did not too hard. theres not much stretch to it, but what i covered wasn't that hard.
July 23, 201115 yr Author rings for the rear fill mids. 1 12" and 2 8's behind each front seat.was going to mount them and start getting it fleeced up ready for glass, and....
July 23, 201115 yr Where in FL you located? looks like you're close to the puntaedit: the front just rolled by here about 20min ago, you may be in one of the other dozen spots with the same clouds tho
July 24, 201115 yr WOW, I've not seen many Systems using 12" Mids comfortably. I love the eminence Delta series, LOUD n Clean. I will be doing up my 1984 Volvo 240 with suede/ leather interior, With a 4th order wall similar to this one, but you will only see port, subs will be inside chamber.I Wants do (1) 10" with one 8" and a super tweet per door. With a few extra domes in the corners. I hope to get a New Crescendo Concerto 2 Channel but the Sundown amps are nice to, BUT so is the 1000C4!!! arrggh! Im on a budget for this one, but it should be loudI LOVE YOUR BUILD, ITS SO CLEAN AND BOSSY! Im doing (4) 15's of some sort... Thanks for doing it right bro!
July 25, 201115 yr Author thanks!sounds like you have a simliar plan. im running all my mids off of 2 nendo 1600.2 amps. 4 12" delta's with 425w each, and 8 8" delta pro's with about 210w each.tweets will be 8 power acoustic nx-5 bullets (louder than piss) on one of the new nendo 4ch (once the 1000c'4s sell out), but ill use my current 1000c4 until those are released (im picky about having all matching amps)i have 2 1000c4's that ill likely use on a switch for mids behind the rear door/hatch area, for at shows or whatever. im thinking about getting 2 BC2000D cases, and taking the 1000c4 board and fitting it inside that, so they "look" like the match the new line of nendo amps. Navid said it should fit.then i want 2 5500d's for the subs
July 26, 201115 yr Amazing work dude, never though id see you finish a project lol, but top notch work so far, congrats on that. Should be a beast when you done!
July 28, 201115 yr Author Amazing work dude, never though id see you finish a project lol, but top notch work so far, congrats on that. Should be a beast when you done!hahahah
August 4, 201115 yr Author kinda ghetto, but its all good. once its glassed up ill reenforce the rings from the inside and all should be good. kinda hard making these pods since i dont want to glass to the B pillars (most ill do is put a few screws into it) but i dont wanna glass into anything in the car in case i ever take it out to sell the car.yes the 8" rings look ghetto too lol. sorry.
August 9, 201115 yr Author posterboard. gonna put a thin layer of resin, then stick the mat to it, and glass over it.this is behind the front baffle
August 9, 201115 yr Author and then i just did this now, dont know if itll help any sound wise or not, but looking through the port it should look nice with all rounded edges and corners. (glassing over this as well)
August 12, 201115 yr I see you have decided to glass that entire section as well as the corners. Looks good!! Glass away!!
