Posted April 29, 201115 yr bought a 1200d from a CA.com forum member in december 2009. hooked it up to verify that it was working in my buddy's car, but it whined pretty badly. all the cables were properly run. about a month ago i built a box and bought a sub and installed them in my truck. the amp has the same whine it did when i bought it and i also noticed has an "power surge", like there's faulty wiring. and yes, the amp is what is whining. i thought it was just the songs we played to test it but apparently not. i relocated then replaced the power cable replaced the ground and relocated the ground with no change. when playing, it's almost like the bass knob was turned down and at random times turned up to max. well that's not the case because the bass knob that came with the amp does not work either. i've tried running it with and without the knob hooked up and the result ends up the same every time. i switched it to my dad's car and it did the same thing yet again. amp is running at 4 ohms tuned with a multimeter every time. messaged the user and asked if he had that problem before. he stated that when it was cold it did whine a little. i told him it will be a while before i can use it in my application. he said that's fine and let him know when that happened and we would talk then. well i messaged him and he hasn't logged on for five months. what do i do? in multiple applications it did the same thing so even if i didn't have the common sense to run wire i know for a fact the other two vehicles were set up and worked with their systems.
April 29, 201115 yr Author pioneer deck with rcas grounded to the frame 4awg wire knu krystal rca 1200d and a rf p2 sub Edited April 29, 201115 yr by cranberryyumyum
April 29, 201115 yr Can you swap another amp into your setup to test?If the amp is faulty send it out for repair. You bought the amp over a year ago, I do not think the seller is responsible imo.
May 2, 201115 yr Author bmw z4 grounded to the same ground as the battery. bench tester? i've tried my buddy's dd m3 and it works flawlessly.
May 8, 201114 yr Author well that's not necessary. all the shit was stolen last night. happy mother's day
May 8, 201114 yr well that's not necessary. all the shit was stolen last night. happy mother's dayThat's so shitty. I'm always worried my stuffs going to get stolen now, especially since I put a TeamSSA sticker on the car, hope no one figures it out?Would it be worth it to pay your deductible and have insurance cover it?
May 9, 201114 yr damn bro. sorry to hear that. search your local craigslist for it. my buddy found his engine that he put about $3k into on CL the day after it was stolen. people are just asses. good luck.
