Posted June 24, 201114 yr Im getting mixed info like crazy on this one...mainly concerned with keeping voltage drop to a minimum. I've read, more wire, the better..then i've read there was no difference i.e. Sean replaced his 10 y/o 0ga with brand new 2 runs of 0 and he gained nothing...Here's my electrical before you guys ask for it....DB electrical 250a alt and plan on running a XS Power D3100 in the back.
June 24, 201114 yr As long as it's pure copper, wire is wire.The only thing that changes is flexibility and the jacket.
June 24, 201114 yr pure copper 1/0 should be able to do 350+ amps of current.. so that's well within the limits of the 3500.
June 24, 201114 yr Author I was talking about the advantage of running multiple runsWhen I had my 3500, I had two runs of 1/0 gauge running to it.How much voltage drop did you have and what electrical?
June 24, 201114 yr If you really want to, pull a run of 00 to the back battery, but One run should do the trick.
June 24, 201114 yr I was talking about the advantage of running multiple runsWhen I had my 3500, I had two runs of 1/0 gauge running to it.How much voltage drop did you have and what electrical?Stock 180 amp alternator with two d3100s. No voltage drop at all but I never listened to it for extended periods of time at full tilt ~15 minutes. I just did two runs right away when I installed it. You could try one and just monitor your voltage. Then add another if needed.
June 25, 201114 yr Will this do?http://www.audiosavings.com/products/Car-Amplifier-Power-Cable/CADENCE-0-GAUGE-RED-AMP-POWER-WIRE-49-FOOT-SPOOL-NEW/0G15M-RED.aspxCandance 0 gauge OFC
June 25, 201114 yr i think it has mostly to do with battery and amperage from alt. I have had my 3500 a long time, ive ran it with a single run of 0, and now 2 runs, but im getting worse voltage drop now with 2, but again ive done a few other changes, and i think the batteries are not as good. I think if you have a good alt, and 2 good batteries, you dont have much to worry about. Im running a 220 amp alt, with 3 batteries including under the hood, and 2 big batteries in the back, and get voltage drop from high 13's low 14's, down to 12's at idle and while driving mid 13's. If money is not a major issue, i would stick with the 180 amp alt, get 2 good batteries and look into a module to keep your alt charging in the high 14's or 15 volts. but thats my opinionedit : my bad, for some reason i thought you had a 180 amp alt, maybe it was someone else that posted, so scratch that from my response lol Edited June 25, 201114 yr by Hostility
June 25, 201114 yr I recommend two runs of 1/0 (two sets of + and -).I have a Crescendo 3kwp (running @ 1ohm), DC Power 270XP, (2) D3400 and one rune of 1/0 (both + and -). I do see over a 1v drop during heavy bass lines. I will be running my 3kwp @0.5ohm in a month or two and will certainly be adding another set of 1/0.It isn't necessary about alternator amperage. The power transfer between two batteries, one front one rear, can exceed alternator output. For that short burst of power transfer more wire the better
June 25, 201114 yr I do have a good 220amp alt. with a 1.2v booster. http://www.zzperformance.com/grand_prix/products1.php?id=517&catid=107I am waiting on the SMD and nothing is ran, just planning... Looking for batts... I did buy enuf of that wire for 2 runs, mite as well run it...
