Posted October 1, 201115 yr i was looking at the re amp it "says" it will do 200w x2 at 4 ohm. would 100w to 120w be to much i know they are rated for 85 rms. im pretty sure they are under rated so bad idea or go for it? also is it 85w per side or total dont know if this is a dumb question or not.
October 1, 201115 yr Use your gain. And what are they? Can't say what they are rated at without knowing.
October 1, 201115 yr Author sorry ia comp. they are rated for 85wedit: im looking at the amp. i have the ia comps they are rated for 85w i want to put 100 to 120w to them. bad idea? Edited October 1, 201115 yr by steveo50
October 1, 201115 yr Listen for stress and adjust the gain accordingly. It will also be dependent on what you cross them at.
October 1, 201115 yr Author they are passive. i have the amp set at the highest setting i think 250hz. hu is at the highest frequency as well i think 220hz the gain on the amp is about a little more then a quarter of the way up i have not checked with ddm yet. they are not distorting from that i cant tell.
October 1, 201115 yr they are passive. i have the amp set at the highest setting i think 250hz. hu is at the highest frequency as well i think 220hz the gain on the amp is about a little more then a quarter of the way up i have not checked with ddm yet. they are not distorting from that i cant tell.I mean your HPF? How low do you let them play?
October 1, 201115 yr How do you know they're "under-rated"? I see a huge potential for destruction in your case, I'd just pick up a used 125.2 or 100.2 and keep the gains down.
October 1, 201115 yr This..... http://www.amazon.com/Rockford-Fosgate-PBR300X4-Compact-Amplifier/dp/B004T163SY
October 1, 201115 yr I got one of these: http://www.sonicelectronix.com/item_29982_VIBE-Audio-LiteBox-Stereo-2-LiteBox2.htmlIn great condition if your interested.Any amp you go with, just set the gain accordingly and you won't have any issues.
October 1, 201115 yr I have one of these I would sell u. http://www.kandtsales.com/shop/product_page.php?parent_top=Electronics&parent_mid=Mobile&parent_low=Amplifiers&prod_id=830
October 1, 201115 yr Author yea the high pass is at the highest. idk what the hz is it at the highest. i know cuz i didnt adjust it at first and it sounded like i was going to blow em up. i just assume 85 rms is rms and would handle like 100ish watts
October 1, 201115 yr yea the high pass is at the highest. idk what the hz is it at the highest. i know cuz i didnt adjust it at first and it sounded like i was going to blow em up. i just assume 85 rms is rms and would handle like 100ish wattsThe output from an amplifier is going to vary depending on the frequency being played. So you could have it hooked up to your "100rms amp" and in actuality the driver is being powered with much much less.If I were you, I'd buy an amp that fits your budget, fits your space, and advertises 80watts rms or more.
October 1, 201115 yr Author Ok I get it. I thought that's how to pair an amp and comps. I wanted to make sure I'm doing this right.
October 1, 201115 yr Technically you could use a 500watt rms per channel amp, it's all about setting the gain.
October 2, 201114 yr It's not as much overkill as you think. The dynamics of music make having the extra power, or overhead, a very good thing. Impious has a thread on here that explains in great detail the how and why of it. As long as a person is responsible with the gain and volume and listen for stress from the speakers then it will be fine. Here's the topic on Amplifier Headroom.
