Posted November 1, 201114 yr Names Frozone (yes the DJ)I'm on youtube. Alot.I swag. AlotI love my Scion xb 2010. AlotI recently learned about Sundwon and i like what i see. Alot.I DIY. AlotI mess up. AlotI enjoy. AlotI play fat beats. AlotI ask questions. Alot.I DJ. AlotSwag.If you vids of my car and other stuffhttp://www.youtube.com/djfrozonewww.djfrozone.comI'm a member of scionlife and scikotics so if you are on that too hit me up!I'm here how to learn to make an affordable banging minimal system on a college students budget.
November 1, 201114 yr looking at one of your vids.. im glad you made it here.. you should never zip tie your amp and a mount. you need to address your fuse near your battery, well start with those.. unless you have already fixed those.
November 1, 201114 yr Author yeaa i moved that amp its in the rear above my rear tire. and yea i got an inline fuse on that battery line. i've pretty much self taught and learn at every show i go to. what i want now is one of those battery connects so i can just run a amp/light wires right into that and quick disconnect if i need to without disconnecting the battery.Also i'm from cincinnati but go to school in oswego,ny so that area and binghamton, ny im around alot. I wanted to post questions about the following and want to put it in the right sectionWhat do ohms mean?I have a rockford p110 enclosed box (factory enclosed)Im debating on just getting one SA-8 to replace that.But. Dont know what amp or how to build a box. so i should really get on that. IM trying to make moves this winter. also want critques on my current system and hear what i can do to improve it or fix issues with it.
November 3, 201113 yr When you're starting fresh make sure you READ all you can bro. Make sure you find what you want and buy what you like. Nothing sucks more than buying something AGAIN because of poor planning.There's plenty of info here so read away and welcome!
November 3, 201113 yr i smoke crack alot! welcomesee i assumed it was meth.. but hey no one is perfect !
November 5, 201113 yr Welcome, "Ohm" is a measure of resistance. Just Google it. I second something bigger than a 8" sub. Unless you just can't fit anything else.
