June 7, 201412 yr As someone mentioned further up I would seperate each fuse, instead of one large fuse block, Because if one wire shorts its doubtful that all of those fuses would blow quickly enough to prevent any damage. If you used all 300 amp fuses, 1200amps could cause some pretty instant damage. I notice you keep pressing this. I'm not sure if you're aware of how MECA works, but you want straight bars to share the amperage rating of a single or just a small amount of fusing amongst every positive run to the sub amps. If you find my information incorrect explain how you'd do it differently for our usage.
June 7, 201412 yr As someone mentioned further up I would seperate each fuse, instead of one large fuse block, Because if one wire shorts its doubtful that all of those fuses would blow quickly enough to prevent any damage. If you used all 300 amp fuses, 1200amps could cause some pretty instant damage. Yep. We do not ever recommend using a single fuse larger than 300A in a vehicle. Too much of a fire hazard risk. Everything needs to be separated.
June 8, 201412 yr Custom mini cock blockUmm, what?I'm sure I know this is to pac-lc1 all bass at once, but cock block? Lol Edited June 8, 201412 yr by nadcicle
June 8, 201412 yr Lol auto correct, bowman not blowmanPerhaps sharing this with Scott would give him a good chuckle haha
June 9, 201412 yr Author Plan is to have it playing Tuesday. Final testing by Wednesday. "Maybe" a stripper pole will be added before slam.
June 9, 201412 yr You make me feel lazy Makes me feel poor. Of course, going for broke like this can make anyone poor. Hopefully everything goes off without a hitch when it comes time to make some noise.
June 9, 201412 yr Really impressed by this build so far. Love the rear layout and cant wait to hear it. I admit, I may be alittle scared lmao!! Should be just flat brutal. Gonna make me step my game up this go round!
June 9, 201412 yr Really impressed by this build so far. Love the rear layout and cant wait to hear it. I admit, I may be alittle scared lmao!! Should be just flat brutal. Gonna make me step my game up this go round! That makes two of us. Mine isn't as purdy as his
