Posted February 7, 201214 yr I am new and am designing a ported box, it is 4.1 cubed inside for 1 15 and i want to tune low. how big should the port be so the air speed is not too fast?
February 7, 201214 yr That's dependent upon several things. There are calculators and formula's for figuring this too.PORT AREA CALCULATOR <-- This one is a pretty popular one. The amount of port area you plan on using depends on the xmax of the driver(s) you're going to use, tuning, and space primarily. The more port area you want to use the longer the port has to be so the more space it's going to either take up in the enclosure or the larger the enclosure has to be to account for the port. Some people don't like using really large ports for SQ related reasons, others love using the biggest port they can possibly fit for more SPL. Your goals, enclosure design plans, and space restrictions are going to dictate the end result.
February 7, 201214 yr How much power, and enclosure tuning? Oh and the DRIVER being used. lolIn return, I will tell you port area and port speed. Edited February 7, 201214 yr by stefanhinote
February 7, 201214 yr Author SSA dcon in approx 3.5 cube net box tuned to 32 HZ for now i will be using a 130w rms amp. will be upgrading to 300wrmsright now i am planning to be using a 6" diameter port that is 15" longBut i dont even have the sub in my hands yet its in the mail so this is all planning Edited February 7, 201214 yr by Dubstepz
February 7, 201214 yr Author I calculated the port size for a round port and it came out to be 8.24 and if i calculate the length than it has to be 36" long to be tuned correctly. i dont have that depth
February 7, 201214 yr Instead of making a standard slot L- port, you can keep the length by making it a labyrinth port.
February 8, 201214 yr How much power, and enclosure tuning? Oh and the DRIVER being used. lolIn return, I will tell you port area and port speed.I have a ZCON 15D2 and a DC Audio 2.0K. Tuning to 33hz. I want to use an 8" port with aero end caps. Should I use 1 or 2?Enclosure is size up to you really. Tell me what's best. Thanks
February 8, 201214 yr I calculated the port size for a round port and it came out to be 8.24 and if i calculate the length than it has to be 36" long to be tuned correctly. i dont have that depthI suck ballz at designing enclosures. But if you have a size restriction make it known
February 8, 201214 yr How much power, and enclosure tuning? Oh and the DRIVER being used. lolIn return, I will tell you port area and port speed.I have a ZCON 15D2 and a DC Audio 2.0K. Tuning to 33hz. I want to use an 8" port with aero end caps. Should I use 1 or 2?Enclosure is size up to you really. Tell me what's best. ThanksI came up with:Using: 50.27 in^2 Port AreaVent Mach: 0.113Vent Mach: 127.828 ft/secVent Mach: 38.963 m/secThat's for one 8" circular port, with flared ends I'm not sure how much exactly less you can get away with.
February 8, 201214 yr SSA dcon in approx 3.5 cube net box tuned to 32 HZ for now i will be using a 130w rms amp. will be upgrading to 300wrmsright now i am planning to be using a 6" diameter port that is 15" longBut i dont even have the sub in my hands yet its in the mail so this is all planning300wattsone 6" circular port32hz tuningUsing: 28.27 in^2 Port AreaVent Mach: 0.044Vent Mach: 49.289 ft/secVent Mach: 15.024 m/secIf your box is close to 3.5 cubes, with a 6" diameter port, and 15" long, after displacement, your tuning would be around 34-35hz. Which is certainly fine, it's not like a few hz is going to make a whole lot.If your using flared ends, then disregard this last bit, I'd have to do a new calculation for that.
February 8, 201214 yr How much power, and enclosure tuning? Oh and the DRIVER being used. lolIn return, I will tell you port area and port speed.I have a ZCON 15D2 and a DC Audio 2.0K. Tuning to 33hz. I want to use an 8" port with aero end caps. Should I use 1 or 2?Enclosure is size up to you really. Tell me what's best. ThanksI came up with:Using: 50.27 in^2 Port AreaVent Mach: 0.113Vent Mach: 127.828 ft/secVent Mach: 38.963 m/secThat's for one 8" circular port, with flared ends I'm not sure how much exactly less you can get away with.What enclosure size is that based on?
February 8, 201214 yr How much power, and enclosure tuning? Oh and the DRIVER being used. lolIn return, I will tell you port area and port speed.I have a ZCON 15D2 and a DC Audio 2.0K. Tuning to 33hz. I want to use an 8" port with aero end caps. Should I use 1 or 2?Enclosure is size up to you really. Tell me what's best. ThanksI came up with:Using: 50.27 in^2 Port AreaVent Mach: 0.113Vent Mach: 127.828 ft/secVent Mach: 38.963 m/secThat's for one 8" circular port, with flared ends I'm not sure how much exactly less you can get away with.What enclosure size is that based on?Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...It's in the loudspeaker cookbook, although I'm sure it's in a thousand other books too.
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...It's in the loudspeaker cookbook, although I'm sure it's in a thousand other books too. It is. Reading it through the third time, actually. My "bedtime" reading isnt absorbing lol
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...It's in the loudspeaker cookbook, although I'm sure it's in a thousand other books too. It is. Reading it through the third time, actually. My "bedtime" reading isnt absorbing lolTry in the morning with a cup of coffee.
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...It's in the loudspeaker cookbook, although I'm sure it's in a thousand other books too. It is. Reading it through the third time, actually. My "bedtime" reading isnt absorbing lolTry in the morning with a cup of coffee. I wake up at 4:20am. I am screwed. Glad there is a Stefan around to solve my port volume issues!
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...It's in the loudspeaker cookbook, although I'm sure it's in a thousand other books too. It is. Reading it through the third time, actually. My "bedtime" reading isnt absorbing lolTry in the morning with a cup of coffee. I wake up at 4:20am. I am screwed. Glad there is a Stefan around to solve my port volume issues!You wake up at 4:20 just to get high? I made a calc pertaining to some of the stuff: http://portsgalore.stefanhinote.com/Might find that useful.
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...It's in the loudspeaker cookbook, although I'm sure it's in a thousand other books too. It is. Reading it through the third time, actually. My "bedtime" reading isnt absorbing lolTry in the morning with a cup of coffee. I wake up at 4:20am. I am screwed. Glad there is a Stefan around to solve my port volume issues!You wake up at 4:20 just to get high? I made a calc pertaining to some of the stuff: http://portsgalore.stefanhinote.com/Might find that useful.Its been bookmarked for me since you created that thread.
February 8, 201214 yr Enclosure size doesn't play any role in determining port velocity. It's all about the restriction of airflow (port area), how much air the driver is displacing (acoustical power output), and the tuning of the enclosure.I really need to hit the books...It's in the loudspeaker cookbook, although I'm sure it's in a thousand other books too. It is. Reading it through the third time, actually. My "bedtime" reading isnt absorbing lolTry in the morning with a cup of coffee. I wake up at 4:20am. I am screwed. Glad there is a Stefan around to solve my port volume issues!You wake up at 4:20 just to get high? I made a calc pertaining to some of the stuff: http://portsgalore.stefanhinote.com/Might find that useful.Haha. I haven't smoked the dope in many many years. Cool calc bro! I cant wait to check it out!!!!
February 8, 201214 yr I made a calc pertaining to some of the stuff: http://portsgalore.stefanhinote.com/Might find that useful. Nice!!! Link Saved!!!
