Weird, I want amazing SQ in my front stage. Going through all this work with Sound Deadener Showdown, Diamond, Morel, Audiosystems, and a PRS.
Then, 2 18"s on 12k behind my head. lol
Hell yeah! Win an sq comp with a car that does high 50's and prove that "sql" isn't a myth.
Maybe I can. lol
I know my wall sounds amazing at low volume, when I blend it with the front stage it sounds fantastic.
  • 2 weeks later...
  • Replies 234
  • Views 37.8k
  • bassahaulic
    bassahaulic
    Got the first videos of the wall!! I used my friend DC L4 XL 18"s for the weekend to see what all needed to be worked on before my subs went in at full power. The M4a was @.5ohm, so a good bit of juic
  • thats the same one i have i showed you last time you were at the house.. its a stinger fan ebay
  • bassahaulic
    bassahaulic
    Well metered the new N3's, first I metered with the D9's wired to 1ohm each.   And it did this at 44Hz.   The RE MT's wired to .5ohm per amp did a 157.7 after the deadener was added. Then I did th
I have a few little updates. :)
One being, I got a small Kinetik HC600 to put the Audiosystem amp on to act as a buffer between the huge pull of the 2 D9's and the amp. Also getting a 80 amp Stinger Isolator to make it 100% unaffected.
Also, I metered the PT with just one working 18" and a single D9 powering it, just for shits and giggles.
And MY RE-CONE IS OTW!!!!!!!!!!
Good shit bro. I need to work on my front stage next..
Man I LOVE this build! I also drive a pt and have admired this build for the past year now, ever since I first saw twisted's video of your wall I've been working towards walling mine and now I'm hopefully about to start with a buddy of mine soon in the next few weeks! Excellent numbers! This build has been my biggest inspiration for my own build hands down and I have learned many different things about SPL with Pt cruisers from you.
-Btw what was your voltage like when the Singer alternator was working? Mechman offered to build me one that was 250 amps or 320 with a turbo pt bracket.
Anyways sorry to thread jack awesome build man!
Can't wait to set in this machine with my SQ disc ... See you soon
Man I LOVE this build! I also drive a pt and have admired this build for the past year now, ever since I first saw twisted's video of your wall I've been working towards walling mine and now I'm hopefully about to start with a buddy of mine soon in the next few weeks! Excellent numbers! This build has been my biggest inspiration for my own build hands down and I have learned many different things about SPL with Pt cruisers from you. -Btw what was your voltage like when the Singer alternator was working? Mechman offered to build me one that was 250 amps or 320 with a turbo pt bracket. Anyways sorry to thread jack awesome build man!
The Singer alternator is now 100% working, and kicking ass. With both D9's in before I messed a sub up I was getting into the mid to low 11's under full tilt.
That might change in a while when I get the new re-cone and can tweak things a little.
The Singer mounted directly to the factory bracket in my 01 Non-Turbo, I preferred that over changing the whole bracket.
Sweet thank you for the input, and good luck with the rest of your build! Maybe one day when I can drive to some shows I can meet you in person and hear this thing.
Going to be getting some Fi N3 18"s
Edited by bassahaulic
After having the n2's myself i couldn't imagine the n3's in your setup. Should get nasty on that power and id expect a considerable gain.
I have ur n2s! and their fuckin loud!
Lol nice choice drew cant wait to see the diff in numbers
There will be a difference in ohm load.
The MT's are Dual 1's putting each amp at .5ohm.
The N3's are Dual 2's, putting each amp at 1ohm daily, and .25 for burps. Should be nice!
Hell yeah man! Can't wait for results!
Well, got something epic done to the PT. Been wanting to do this for a while just got to it.
I have a Mike singer 240 amp alt, was PCM regulated, now, externally.
Transpo 911-02R External Regulator. Any of the regulators that look like this, are ALL made by Transpo.
The wiring is dirty for the moment, until tomorrow and I can get to the shop.
First test.
Possible normal driving voltage.
hellz yeah!
  • 2 weeks later...
And the deal is done.
RE MT 18"s are sold!! And I'm going to pick up my Fi N3's tomorrow!!
Oh snapz!!!
Fully loaded, Dual 2. With cooling a 7 spiders.
F062AC76-08C1-49AA-9127-2C2C9CDE28F6-343
A little rusty, but typical for Louisiana subs. lol
308AFCBF-3CD0-41EC-9B9D-E40F558D5671-343
8CBA8039-33A4-42FD-998E-2A5A1CD8557B-343
"Rusty", nothing a little touch up can't fix...
