Posted July 6, 201214 yr im stuck... help me.both 1 ohm daily .25 burps. on 300 mechman and 3 dekas Edited July 6, 201214 yr by bigjon
July 6, 201214 yr Author You've been sundown for as long as I can remember. Why change now?J thats why its hard for me foot print is an issue....... and well...... thats about it really.
July 6, 201214 yr You've been sundown for as long as I can remember. Why change now?Jthats why its hard for mefoot print is an issue....... and well...... thats about it really.How much is the difference in footprint, dependable output, and pricing?J
July 6, 201214 yr Author DD Dimensions - inches 30L x 11.9W x 2.8Hsundown Dimensions 12.20"(W) X 2.68"(H) X 27.56"(L)sundown NS1RESULTS:starting voltage 14.8vvoltage drop 12.7vwired to .5ohm rising to 1.39ohm @ 45hzrail voltage 97.3vacamperage 70amptotal output = 6811w i keep finding, this in refrance to the DD2. Specs: Easily a 7k amp7,600w @ 14.4 volts9,000w @ 16 volts and i talked to 1 person that said he clamped it .. he said 6600 watts @ [email protected] volts starting ohm load at was .67ohms.
July 6, 201214 yr DD amp is a amp that will appreciate. The NS-1 will not.I believe the Z will also do more power, and run .25ohm more stably then the NS-1.
July 6, 201214 yr DD amp is a amp that will appreciate. The NS-1 will not.I believe the Z will also do more power, and run .25ohm more stably then the NS-1.Sounds like speculation to me.
July 6, 201214 yr I voted Sundown because of the customer service, but I would seriously look at the new Crossfire amp. It would outperform both amps listed and I hear they have incredible customer service too.
July 6, 201214 yr I vote sundown. I've seen those dd amps in action. At low impedance they are very sensitive to low voltage situations. I haven't seen the sundown NS-1 in action, but I did see how your 4500 performed, and itfthat's any indicator of how the NS-1 will perform, I'd stick with the sundown.
July 6, 201214 yr Author I've seen those dd amps in action. At low impedance they are very sensitive to low voltage situations.they put up a 160 with the truck off, so 12 volts at the ellis reed show. i was shocked. but with there only being 50 made there are not many details and test results.
July 6, 201214 yr Author why only 3 dekas? thats what i have as of now.. i plan to add 1 more.. but thats pretty much it.
