Posted August 28, 201214 yr Well, I was changing the subs to their new box when I noticed one of my Xcon's has a cracked magnet all the way around. I have no idea how it happened or what may have caused it. I haven't noticed any performance issues from it though.Here is the other sub which is finehere is the sub that is cracked
August 28, 201214 yr Author Yeah, I've never seen it before ever.....and it's cracked all the way around.
August 28, 201214 yr Author It's going to have to be sent in, I bumped the box it was sitting on and the magnet shifted and I pressed down on the cone and could feel it scraping against something, so I'm just going to send it in once I hear something from Aaron or Mark.
August 28, 201214 yr You bumped the enclosure and that happened? I'm just confused as I just received one in too big of a package with nothing inside to hold it in place and it was okay. Not from SSA I should add. I can't believe that happened without serious force, that's nuts.
August 28, 201214 yr Author You bumped the enclosure and that happened? I'm just confused as I just received one in too big of a package with nothing inside to hold it in place and it was okay. Not from SSA I should add. I can't believe that happened without serious force, that's nuts.I was moving my old box and it caught the edge of the new one where the sub was sitting and it moved the box a little. I bought these xcons used and they were fine, but they were both shipped in the boxes that SSA used.There is no telling what happened to crack the magnet, they were absolutely flawless when I received the subs and just now after pulling them out and changing enclosures, I noticed something was wrong. (Just yesterday I was playing them for a friend and there was no issues with them at all, no funny sounds or any signs of trouble)
August 28, 201214 yr Author jb weld that bish!! haha jk jk. hope all is well with itThat would probably work....but.....hahahaha
August 29, 201214 yr Wow, that's crazy. Something tells me it was dropped at one point but not hard enough to actually crack anything, at least on the outside. Playing it quite a bit may have caused the crack to grow
August 29, 201214 yr sadly i cant see it being a cheap fix, im sure it needs a new motor and recone of course, sucks man. i also cant see jb weld working, and the magnet is already broken and spread and out of alignment if i read correctly. on the bright side.. if you ever thought of changing your impedance now is the time!good luck buddy,
August 29, 201214 yr Author Wow, that's crazy. Something tells me it was dropped at one point but not hard enough to actually crack anything, at least on the outside. Playing it quite a bit may have caused the crack to growThat could be a possibility...I can vouch for one of them to not have been dropped, had a friend pick it up and bring it to me, as for the other one, it was shipped from up north and who knows what all happened on that journey.sadly i cant see it being a cheap fix,im sure it needs a new motor and recone of course, sucks man.i also cant see jb weld working, and the magnet is already broken and spread and out of alignment if i read correctly.on the bright side.. if you ever thought of changing your impedance now is the time!good luck buddy,I can only hope that it's not too bad! New motor is a must.
August 29, 201214 yr Author That's a wide crack mann...Yeah it is, I'm surprised with how big that crack is and that it is all the way around that it never gave me any trouble, no sounds...smells....or anything! I guess that is a prime example of made in the USA quality!
August 29, 201214 yr Cracks like that, on that type of material usually work their way from inside out.
August 29, 201214 yr I had a Q 15 that broke very simaler to that. but it was dropped by FEDEXCrap that makes me nervous. My Q showed up bouncing around in the cardboard box. Small chip on the magnet but looked ok otherwise. Hope mine doesn't look like that in a few months.
August 29, 201214 yr Admin Wow, that is a first. Got your email, I have a bunch in front to knock out. I believe it should be a simple slug swap, we will have to find out what the cost is a this is the first time for this.
August 29, 201214 yr Author Wow, that is a first. Got your email, I have a bunch in front to knock out. I believe it should be a simple slug swap, we will have to find out what the cost is a this is the first time for this.Sounds good to me, thanks for the quick response!
August 29, 201214 yr Author I had a Q 15 that broke very simaler to that. but it was dropped by FEDEXCrap that makes me nervous. My Q showed up bouncing around in the cardboard box. Small chip on the magnet but looked ok otherwise. Hope mine doesn't look like that in a few months.My Btl had a small chip on the magnet and it performed awesome. I'd just be concerned with cracks or if its multiple magnets, if they were out of alignment.
August 29, 201214 yr Yikes for that crack. The quality of these subs are excellent. It's getting them shipped in one piece. I know even a minor scrape or chip is cosmetic, but when you're buying something new you want it to be in its best condition. UPS and FedEx suck. I would rather pay more for shipping if it could withstand their abuse. Not even purposeful abuse. Lifting 50 lb boxes 8 hours or more takes a toll on a person. Tired equals sloppy. Plus shit does fall in the truck. For packaging, I'm talking using a wood crate, filled with packing peanuts, styrofoam and, memory foam, wrapped in bubble wrap inside a cardboard box with a shim of mdf on all outside edges, stamped fragile in big bold red letters. I would rather have it over packaged and secured. End of rant...
