Posted December 6, 201212 yr Hello! I have a 2000 Camaro with a thunderform 10" sub box (http://thunderforms...._2002/show.html).I was about to get some crappy pioneers but then I came across SSA and am considering the DCON, Skar VVX, maybe a GCON, or something one of you might recommend. My concern is that because the box is so limited (.6 ft3 sealed) if these subs will still sound any good, because I understand that they are engineered to be tuned and be in the right box.I'd be getting a new amp to btw, i'm thinking the Audiopipe APSM-1500.Let me know if you recommend a sub or if you think one of these wouldn't be a good choice for me. Any feedback would really help! Edited December 6, 201212 yr by ryann
December 6, 201212 yr you will need to check the mounting depth but i would go with a Gcon or Icon. a Dcon would be great too but it sounds like you want to run more power. but you didn't really state your goals yet??the skar would a bad choice in general. also, the audiopipe probably isn't the best option either. boston acoustic amps are on sale right now. i'd suggest this, http://www.sonicelec...s-GT-2200.html. 900 @ 2ohm bridge will be perfect for a Gcon or Icon.cheaper but a little less power, http://www.sonicelec...cs-GT-2125.html Edited December 6, 201212 yr by lithium
December 6, 201212 yr You could always try to build a box that fits in the ttop storage area. Or even try to use the pocket on the left side of the trunk to make a little more space..60 is kinda small for anything your trying run 1500w to.
December 7, 201212 yr Author you will need to check the mounting depth but i would go with a Gcon or Icon. a Dcon would be great too but it sounds like you want to run more power. but you didn't really state your goals yet??The mounting depth on the thunderform box is 7 3/4" so it will fit all of the subs mentioned so far.My goal is to get some clear, deep, hard hitting bass for listening to metal and electro.I am most concerned with sound quality over just making my windows rattle, which is why i decided to consider these subs instead of mainstream big brands.And it sounds ironic since im trying to do it with the tunderform box but thats just because I already have that box.I picked the 1500 amp because with the gcon (750w) i can run D4 so the amp puts out 1000 or with the DCON (300w) i could run the S4 so the amp puts out 500, and ive read 4ohm sounds best.the skar would a bad choice in general. also, the audiopipe probably isn't the best option either. boston acoustic amps are on sale right now. i'd suggest this, http://www.sonicelec...s-GT-2200.html. 900 @ 2ohm bridge will be perfect for a Gcon or Icon.cheaper but a little less power, http://www.sonicelec...cs-GT-2125.htmlI'm curious what makes the skar a bad choice in general?Is it better to use a bridged 2ch amp instead of a mono? or is it just easier to find a better quality amp for cheaper that way? because i was also looking into the AQ1200DYou could always try to build a box that fits in the ttop storage area. Or even try to use the pocket on the left side of the trunk to make a little more space..60 is kinda small for anything your trying run 1500w to.I already have the tunderform box, and im trying to keep using it because i need the rest of the trunk space for the car's t-tops. Edited December 7, 201212 yr by ryann
December 12, 201212 yr Author My only concern is that since these are "tuner" subs, by not putting them in an optimal box configuration that they suddenly may not perform as good as mainstream subs designed to work in varying situations like perhaps the alpine swr-10d4 or jl 10w3v3 or pioneer ts-w2502. If you guys think that they will still perform on par or better, then I'll be getting a dcon or gcon.Since my car is a hatchback, it will get plenty loud inside regardless, so i'm more interested in the bass sounding tight.
December 13, 201212 yr you will need to check the mounting depth but i would go with a Gcon or Icon. a Dcon would be great too but it sounds like you want to run more power. but you didn't really state your goals yet??The mounting depth on the thunderform box is 7 3/4" so it will fit all of the subs mentioned so far.My goal is to get some clear, deep, hard hitting bass for listening to metal and electro.I am most concerned with sound quality over just making my windows rattle, which is why i decided to consider these subs instead of mainstream big brands.And it sounds ironic since im trying to do it with the tunderform box but thats just because I already have that box.I picked the 1500 amp because with the gcon (750w) i can run D4 so the amp puts out 1000 or with the DCON (300w) i could run the S4 so the amp puts out 500, and ive read 4ohm sounds best.the skar would a bad choice in general. also, the audiopipe probably isn't the best option either. boston acoustic amps are on sale right now. i'd suggest this, http://www.sonicelec...s-GT-2200.html. 900 @ 2ohm bridge will be perfect for a Gcon or Icon.cheaper but a little less power, http://www.sonicelec...cs-GT-2125.htmlI'm curious what makes the skar a bad choice in general?Is it better to use a bridged 2ch amp instead of a mono? or is it just easier to find a better quality amp for cheaper that way? because i was also looking into the AQ1200DYou could always try to build a box that fits in the ttop storage area. Or even try to use the pocket on the left side of the trunk to make a little more space..60 is kinda small for anything your trying run 1500w to.I already have the tunderform box, and im trying to keep using it because i need the rest of the trunk space for the car's t-tops.the skar isn't good sealed. Gcon would be better (simply look at the TS parameters). Also consider build quality. mono vs 2 channel isn't an issue. the BA puts out plenty of power for what you need. the AQ would be a waste because the extra power wouldn't make an audible difference.
December 13, 201212 yr Mainstream brands or not, all subs are made to be played in in their right enclosure. The brands you find here give you more info about how to run their subs, but the mainstream subs are the same.It would be nice if you could find more room for the enclosure.But if you can go with an SSA Gcon : go for it. You'll love it. I had an Icon and it was monderful !!!
January 9, 201312 yr Author Ordered the GCON!! cant wait to get it, but the build wait time is good since now I have to look for an amp to power the sub. I'm considering the one's recommended by members above, and also doing some browsing of my own.
