Posted February 4, 201312 yr Going to be Deadening the whole rear half of car and doors. Also building box for SSA XCON 15" nothing really special. Will more than likely be using MurderMat MDK for trunk/rear deck and BL for the doors. Will get some before and after videos of the flex and rattle. Will post pics of the car soon.The Car 2013 Forte Koup and current Setup. HU is factory NAV unit with Stock Amp.The XCON i picked up locally for $200.Backseat out and most of trim out, not gonna remove trunk stuff til deadener arrives.Got wood and supplies to build boxBox Design(keeping it simple for now since this is my first box)Enclosure Specifications:Fb = 32 HzVb = 4 ft^3External Height = 14 inExternal Width = 33 inExternal Depth = 27 inPort Width = 5 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 33 x 27Left & Right Sides =Side 1 = 25 1/2 x 11 3/4Side 2 = 26 1/4 x 11 3/4Front = 27 1/4 x 11 3/4Back = 33 x 11 3/4L Port Internal Assembly Parts:Front to Back = 20 1/2 x 11 3/4Extension = 3 x 11 3/4
February 6, 201312 yr Author Little update. Murdermat deadener should be here in the next day or so. Finishing up box build, don't think i did all that bad considering it is my first.Back, sides and port glued in.First coat of resinSecond coat of resin and resined bot of top before i glue it on.
February 6, 201312 yr Author Also what should i put in the rear of the car?? Another set of components, just Mids, or coax??
February 7, 201312 yr Author Update, Murdermat came in. Sub finally in box and in car, not deadened yet. Will post up some videos of flex and what not tomorrow. Will also post pics of Murdermat. Pics of box in car: Yay no trunk left... And actually the way its in there i can't even put my back seat back in... Will have to see if i can turn it while it's in the trunk. Will also post some pics of the box out of the trunk tomorrow as well. Would do it now, but damn this thing is pucking heavy to pick up alone... Plan on glassing the outside this weekend and painting. Anyone have any suggestions as to what to put on the bottom of the box so it will slide easier?? Edited February 7, 201312 yr by Fireitup
February 7, 201312 yr I don't think you would want it to slide around back there getting dinged up. As for the rear you could run a set of coax for fill, and a put a nice set of comps up front if you don't have it yet. Props for scoring the Xcon at a great price and thanks for serving. Semper Fi, I'm a former Marine. Edited February 7, 201312 yr by R3dt34rz
