All models operate from 10v to 16v or from 10v to 18v.
FL1 16v model  -$489 MAP
700@   4 ohm @14v
1260@ 2 ohm @14v
2000@ 1 ohm @14v
FL2 18v model  -$889 MAP
1100@ 4 ohm @14v
2130@ 2 ohm @14v
3800@ 1 ohm @14v
BA1 18v model  -$1489 MAP
1500@ 4 ohm @14v
2900@ 2 ohm @14v
5000@ 1 ohm @14v
EL Nino 16v model -$1789 MAP
1650@ 4 ohm @14v
3400@ 2 ohm @14v
6500@ 1 ohm @14v
BA2 18v model  -$1989 MAP
2100@ 4 ohm @14v
4000@ 2 ohm @14v
7000@ 1 ohm @14v
BA3 16v model  -$2289 MAP
2200@ 4 ohm @14v
4350@ 2 ohm @14v
8500@ 1 ohm @14v
El Jefe' 16v model -2989 MAP
2800@ 4 ohm @14v
5500@ 2 ohm @14v
10k  @ 1 ohm @14v
Edited by Flatline1
When will the prices be up?
Today I didn't get a chance to do it last night but they will be posted today
Our pricing is in line with most other companies in the same power ranges and less than some in the same ranges a skar 4500 is 1449 our 5k is 1489. A sundown 3500 is 1200 so I think our price for the 5k is more than reasonable.
1489 for a 5k amp?!
Do you offer any amplifiers for standard nominal 12v vehicles?
All amplifiers will run @ 12v I guess I should have been clearer the amps operate from 10v to 16v or from 10v to 18v
In that case it would be helpful if you listed what voltage was used per output reading. :)
In that case it would be helpful if you listed what voltage was used per output reading. smile.png
All those are @ 14v
Updated hope that cuts down on any confusion it may have caused
Will these amps be available in the ssa store?
Yes we have partnered with Mark on that and they will be available in the store soon.
sweet
Might be an idea to also show what these amps fo at 16 and 18 volts since they are rated to take that higher voltage. Show where that extra cash goes?
J
They look great but kinda pricy. If I need a good Korean amp, I usually grab an American Bass amp. What makes these better than say a $250 PH-4000 MD? http://www.americanbassusa.com/product.detail/product_id/141 Having trouble justifying cost. Not being a dick, I am legitimately interested.
So every amp should be the same price going by your logic. They are pricey compared to what?
Actually that's not even close to what I said. Compared to other amplifiers, they are more expensive. And yes, all amplifiers with similar features should be priced fairly close. That's like saying 600 horsepower cars should be in all price ranges. Well hell yes I'd love that. But someone paying big money for the same power would probably be disappointed in their purchase. I was asking what made the amplifier's price higher than comparable models as there could be difference to make it worth the price. I wasn't being rude, nor was I trying to stir the pot, I'm gathering information. Thanks for adding a high level of maturity to the topic.
  • Popular Post
The problem with such is that there isn't any good way for the average person to empirically determine which is better. You can test drive vehicles, see which handles better, feels more comfortable, and which feels faster. With amps that's much harder to do, and especially in a car environment where it's unlikely you could hear a difference between one and another for SQ, or output (unless the power difference is huge, talking about nearly double the difference in power). So the only thing left is the manufacturer and their reputation. Who do you believe has the resources to design a better amp?
At least that's my opinion.
Glad to see you're on here. Mark @ SSA came down to Tampa after SBN to meet up with Robin, myself and others. He seemed impressed with our vehicles (mostly Robin's Tahoe). But my 2 12s on the FL1 were impressive, pretty sure his wife got a mini hairtrick from my truck. Don't feed into the trolls, they feed off forums.
So here are sizes of the amps to give you a idea of the footprint of the units.
FL1 2k is 12in wide x 2 in tall x 15.5 long
FL2 3.8k is 12in wide x 2in tall x 26 in long
BA1 5k is  13in wide x 3 in tall x 24 in long
El Nino 6.5k 13in wide x 3 in tall x 28 in long
BA2 7k 13in wide x 3 in tall x 34 in long
BA3 8.5k 13in wide x 3in tall x36 long
El Jefe 10k model 13 wide x 3 in tall x 38 long
nice foot prints
Thank you sir these were designed to be able to fit in small areas like your crx and pandas and things of that nature. These are very efficient and we have been able to tell major differences in current draw. I personally had a 3500w amp from a company that is sold here in the US that playing full tilt would go into protect. When our proto arrived we did a direct swap and could play all day long with no issues. Some of our team members did the same with their equipment and noticed differences.
i currently have a NS1 love the amp but i need more power and i have 0 space left,  and i just checked specs on its footprint and even your 6.5  is larger :(
how long is the NS1 im not familiar
2.5 tall x 12 wide x 29 at the mounting feet
